OSTC3 Battery Cover
Yeti42
OSTC3 Battery Cover
Post by Yeti42 »
I have just received a new OSTC3 from the main agent in the UK.
On opeing the battery compartment I found a small piece of metal swarf in the battery compartment and a much larger piece hanging from the battery cover.
The thread has been machined on the battery cover and then a groove has been cut at the back of the thread which leaves an increaasingly thin piece of thread which falls off, hence the swarf.
I have cleaned mine up but this leaves only one turn of thread on the cap.
Take a close look at yours next time you change the battery.
ClaudeDive
Re: OSTC3 Battery Cover
Post by ClaudeDive »
I confirm to have on the cover of my battery compartment a small swarf not yet detached from the cover but not very good and kindly on the machining level,
[left][/left]
Moreover I don't find very making safe from a mechanical point of view to have only one net of threading of just one turn on the cover for a diameter of approximately 12 mm
[left][/left]
The threading of the cover which is an important point for security of the sealing of the OSTC3 will deserve to be improved, and to see to be replaced.
[left][/left]
[left][/left]
Cheers ;)
