OSTC 2N / 2C Battery Voltage - Batteriespannungen
Posted: 05 Jun 2014, 07:45
by Rob
is there any information about OSTC2N and/or OSTC2C Battery voltages?
-When (voltage) is the battery fully loaded?
-when (voltage) empty?
-when (voltage) should i consider not to dive anymore and reload the OSTC?
-when (voltage) should i consider a Battery change?
gibt es irgendwo die Informationen über die OSTC 2N oder 2C Batteriespannungen?
-bei welcher Spannung ist der Akku geladen?
-bei welcher Spannung leer?
-bei welcher Spannung sollte ich nicht mehr damit tauchen und den OSTC laden?
-bei welcher Spannung sollte ich den Akku wechseln (lassen)?
best regards
viele Grüße
Re: OSTC 2N / 2C Battery Voltage - Batteriespannungen
Posted: 05 Jun 2014, 16:06
That's not easy to tell. It's recharged up to 4.15V, then charging is stopped and the voltage drops to the nominal voltage of 3,7V quite fast (Some weeks when not in use, some hours when used). Also, the contact voltage is a function of the temperature.
2.5V is the absolute minimum. Anything below 3.0V is shown as empty.
3,3-3,4V
Li-Ion batteries don't like deep cycles. Recharge when about 70% are used and the battery life will be at it's maximum.
> change?
Anything below 2,5V causes damage to the battery. As a last protection the battery is disconnected between 2,6V and 2,5V with a software-independent circuit.
Posted: 10 Oct 2014, 10:11
by CodyItoras
Rob Wrote:
> Hello,
> OSTC2C Battery voltages along with solar panels manufactured by solar panels manufacturer?
> change?
> Hallo,
> (lassen)?
> best regards
> viele Grüße
> Rob
Hello friend were you able to collect some information about battery voltage? Even I am trying hard so can you help me out?
