failure after surfacing after a real dive
Posted: 28 Apr 2009, 11:17
Just back from a diving holiday in Sharm el Sheikh/Egypt(before I went on holidays havent't been in the water again with my ostc, but did a couple of testdives via my laptop and seemed to be ok, and kept my ostc in handluggage at all time during the flight).
Done a couple of tech dives there...
But not with my ostc...
Day one was a recreational(max 30 to 35m depth on AIR) day of diving where I was going to test my ostc to make sure he was ok, and putted on my old suunto mosquito and bottom timer too as backup, normal dive profile, no decompression dive).
During the dive my ostc was OK.
Surfaced, rinced my ostc in a bucket of fresh water, went up to the sun deck and put my ostc in my backpack in the shade.
Went to the bar on the boat to get myself a bottle of water, and went back to sundeck to have a look to my logbook on the ostc to put everything into my "paper" logbook and heard something beeping in my backpack...
It was my OSTC , he was diving again on the surface at a depth of about 12m( and when he went back to surfacemode, nofly stayed on zero , but desat goes up all the time, and the mBar reading stays on 2277 all of the time), diving logbook had no dives registered, so i couldn't delete the dives, even went to the menu and did a reset all,tried changing the settings from GF/OC to normal OC nothing canged...)
Since we were going to do some tech dives the days after , I asked the manager of Tekstreme diving if he had the software for the ostc on his laptop, yes he had, since he has been using yhe ostc for a long time also...(although he still uses v1.22)
Tried with putting on v1.30 again, uploading ok but got following message on the OSTC:
Unexpected reset from Divemode!
Please help and report the Debug information below:
rrFrZc. 13 11
128 48 0 131 128
0 0 0 192 0
I haven't used my ostc again during this trip , but did my dives on my good old back-up bottom timers...
can anyone tell me what the above debug information means , and what it means to my ostc(?sent it back to Heinrichs Weikamp for further investigation?)
Since it is the second time i get these "false" mBar readings (sent my ostc back the first time and new pressure sensor was put in it , real good and fast service on that one thanx again for that, everything seemed to be ok if I simulated a dive then, but with a real dive it went wrong again after surfacing...)
Thx in advance,
Alain.
