Not possible to download
Hi
I can not download my dives from my OSTC 2N, I have tried several cabels, several computers, several different programs and i have updated the drivers.
NB: I can charge the OSTC from the computers
Could anybody here tell me how to proceed from here, please.
Michael
OSTC 2N sn#3933
Michael
OSTC 2N sn#3933
Re: Not possible to download
Do you know anyone else with a working computer/OSTC setup you can try with? What software are you trying to download with?
Hi
Hi
I have been trying to do the downloads with Diving Log, jDive and OSTC Tools
Michael
OSTC 2N sn#3933
Hi
Michael
OSTC 2N sn#3933
Not before, it worked straight out of the box - then suddenly - no downloads. An then i tried FTDI drivers to no avail.
Michael
OSTC 2N sn3933
Michael
OSTC 2N sn3933
Check things systematically instead of trying all your cables and computers.
a) Is the computer recognized from the PC (Device Manager)?
b) Does the OSTC see that it's connected (Battery symbol is turning red)?
If a) and b) are true the hardware is fine and you can download the dives. No need to install any drivers.
In most cases the cable is broken or the contacts in the OSTC ae a bit wet or corroded. Both can be fixed with some WD40. When testing other cables make sure they have a small head that fits inside the USB bulkhead of the 2N, when not fully inserted the unit may charge but may not communicate.
Hi
> Manager)?
a is false
b is true
I will try with some WD 40
Michael
> Manager)?
a is false
b is true
Michael
Hi Again
I have tried with WD 40 - this does not work any better - and I have connected another OSTC 2N with my cable to my PC and this works flawless.
So just to sumarise: my OSTC 2N is not connetable to PC anymore. What can I do ?
Michael
OSTC 2N sn#3933
Michael
OSTC 2N sn#3933
contact us directly: info@heinrichsweikamp.com - in most cases we can clean the port here and it will work again.
clean the port here - where, online? You're great company!
-D
OSTC 2N 4689
divewithkarim
Hello Michael
Any success with your computer? Facing the same problem, even battery not charging and DW40 useless..
Karim
OSTC 2N 4427
Karim
OSTC 2N 4427
Hi
I did send my OSTC to HW, they did look into things: and yes my computer is dead.
, and apparently not fixable.
Michael
ex, aka dead: OSTC 2N sn#3933
Michael
