v2.90 cannot turn of CF69
nodekh
no matter how hard I push piezo switch CF69 won't turn off...
OSTC 2N 4689
nodekh
Re: v2.90 cannot turn of CF69
I assume that possibility to change conservatism shows while diving in divemode menu. When will it be avaliable? When diving in NDL, or only after showing first decompression stop?
OSTC 2N 4689
While in dive mode, press the menu button to enter dive menu. there you'll find the option to change to an alternativ GF... But only if CF69 is ON!
nodekh
tried today, and there's no option except for Gaslist,Decoplan, space, Display, and Exit
OSTC 2N 4689
nodekh
Use right button to display @gf on the right bottom of the screen
And than use left button for Menu
You're right mate! The custom display must show GF, only then the menu
option will appear...
Somehow a strange an illogical behaviour in my eyes too...
nodekh
well, on the second thought it's logical in some way. You must see which GF_lo/GF_hi you have set while underwater regardless of what you remember you set before the dive. Then you may change from more to less conservative in some critical situation.
On the other hand shouldn't the choice be done between 2 gf sets in "choose gf" menu regardless of what the custom display is displaying?
OSTC 2N 4689
nodekh
What if someone forgets to turn on "show gf" on custom display before the dive and some crisis ocurs underwater?
OSTC 2N 4689
nodekh
if you plan, you set
if you plan, you know what you have to do in case of crisis
if you plan, you use your brain
> eyes too...
I don't think so. It also shows ResetAvr when the stopwatch is used...
> eyes too...
nodekh
Thx, I agree. But life shows that even if you plan, something may go wrong. There are no machines and no people who act faultlessly.
OSTC 2N 4689
Your opinion and you're the Master
I just want to say that i don't see any reason why not to put the "Toggle GF" option into the dive menu - regardeless what is actualy displayed in the Custom View, as long CF69 is ON.
What is your idea behind the dependency of the Custom View and the menu option appearing (or not)?
There is not enough space in the menu for "Set marker", "Reset Avr" and "ToggleGF".
Ok, i see.
Suggestion: Why don't you move the "Display" option to the general settings? This is something one can set before the dive, not? I've never used this option during the dive so far...
Ok, i see.
Stephane
Now we need only another two options from the divemode menu removed
and we have space for everything.
> everything.
Just add the "More" Option (the same like in the Gaslist) to the dive menu list. Then you don't have to remove anything at all... (:D
> everything.
nodekh
