Update issues
Posted: 16 Oct 2014, 19:28
by divewithkarim
Hi Matthias
If possible to send me links to bootloader v1 and any old stable version of the firmware.
I tried to connect my dead OSTC and tiny bootloader found it on COM3, I tried again to update & this is what I get:
HEX: 0 min old, INHX32,18Fcode+cfg, total=92240 bytes.
ERROR!
Not found!
Still my OSTC is dead.. Help please
Re: Update issues
Posted: 16 Oct 2014, 19:56
(I moved this issue into a separate thread).
Your're still using the bootloader v2. It won't wake-up your OSTC from this state. Please don't try anything with the bootloader v2 with your unit. It's possible that you damage it permanently.
As told, please use the bootloader v1. It's all written in this post: read.php?2,4071
Read the section beginning of "If you have firmware <1.90:"
3: Step:
Update process (Windows):
- Download Bootloader v1 program: http://www.heinrichsweikamp.com/?id=145&version=en
- Download the correct HEX file! The file for the Mk.2 is called "mk2_v280_stable.hex", for example. http://www.heinrichsweikamp.com/?id=57
- Choose correct HEX file in the bootloader file dialog: "Browse"
- Choose correct COM-Port in the bootloader (The bootloader searches all COM-Ports automatically)
- In the OSTC Mk.2 Reset Menu, choose "Reboot OSTC" and confirm
If the Menu entry "Reboot OSTC" is not available (e.g. a wrong firmware has been installed), the reset can be triggered with a magnet on the back of the OSTC Mk.2. "Reboot OSTC" and the magnet have the exact same effect on the OSTC Mk.2
- Press "write" at the bootloader within 10 seconds
- Wait about 1min.
Hope this helps,
Re: Update issues
Posted: 16 Oct 2014, 20:37
by divewithkarim
Hi Matthias
Posted the following in Firmware3:
I tried bootloader V1 and JDivelog to resuscitate my OSTC2, even my PC system manager recognize the port COM3 when OSTC2 is plugged. But JDiveLog is sending: Could not establish handshake. Did you press RESET? And Bootloader V1 is showing the following:
ootloader for HeinrichsWeikamp OSTC,
based on TinyBootLoader, v.1.9.5 written by claudiu.chiculita@ugal.ro
[www.etc.ugal.ro]
Connected to \\.\COM3 at 19200
HEX: 3 hours old, INHX32,18Fcode+cfg, total=92679 bytes.
ERROR!.
I'm using a magnet during the all process, but confused smiley.
Help please.
Re: Update issues
Posted: 17 Oct 2014, 09:10
by scubatinoo
My advice: Don't use JDivelog for firmware updates... In the past i had several issues with JDivelog and as far as i know the software is not up to date with the OSTC-Firmware...
You should have a look at OSTCPlanner (https://ostc-planner.net/wp/download/) instead. This software worked always for me, both on Mac and Windows!
