OSTC Sport Companion
Posted: 21 Oct 2014, 15:00
Hi, I received my new OSTC Sport yersterday and I am not able to communicate via the companion software. I have the same issues that the post about the problem that Max described here: read.php?6,13770
My computer is an Asus UX302LA (recent) and running under W8.1
The Bluetooth connection is OK (I tried with my Samsung phone).
The OSTC is recognized as OSTCs 0442 with mac address.
When I go in the Bluetooth menu of the OSTC it says Starting and then Done.
When I open the Windows Icon Bluetooth OSTCs442 it says no service or connection to a remote peripheral device and the OSTC stops bluetooth after 2 minutes.
When I open OSTC companion I cannot access to the changing of communication port. When I open the taskbar Bluetooth Icon I have COM3 outgoing for OSTcs 0442 'SPP Dev' and COM4 for incoming. In the properties of OSTC442 events I can see the device installed (bth.inf)
I tried the software you OSTC Companion_comport and didn't bring it running. I putted it in the OSTC 0.21.1 folder and added all the files it was searching for that I found on my computers but at least I had an error.
I tried also running the companion as Administrator, running in W8 or W7 compatibility mode without result. The power management of the bluetooth has also been unchecked.
Have you something I should try ? At last I would try to buy a external bluetooth adapter if you don't have a solution, but my internal seems to work because I can exchange files with my phone.
