Hello
I can see that people have had similar problems but I am at my wits end.
I have followed all of the instructions in previous posts, many cables, installed all the drivers available but I can still not get my OSTC to connect because no matter what I do I never get offered a COM port.
This is the first time that I have used the OSTC planner after instal so have never been able to connect.
Any advice etc would be gratefully received.
John Campbell
OSTC 8046
OSTC Planner No COM Port Mac Book Air
Re: OSTC Planner No COM Port Mac Book Air
Hi
Did you have a look at Systemreport > Hardware > USB? There should your OSTC be listed if connected AND turned on. If not, check too
- that you're logged in with an admin-account
- that your OSTC is connected to an USB-port on your Mac and not on a Hub (i have problems with the hubs too!). Unplug all other USB-Devices...
- try to push the cable at your OSTC slightly in different positions. Depending on the cable some of mines only work if i push them slighly down...
- try it again, and again.
So two years on and still no joy!
Did you try the things that Scubatinoo suggest?
