OSTC Planner
Posted: 17 Jan 2015, 21:05
by Smiler1968
Sorry if it's bad form to use this forum to ask about another piece of software but I couldn't think of anywhere more appropriate.
Is anyone else using OSCT Planner at the moment? Are you having any problems? I have recently installed it onto a Mac and have updated the OSTC 2N firmware to 3.00 without any problem. However, when I try to upload the CF's I get an error message.It appears to have uploaded CF1 but stalls on `CF2 and gives the error message. The OSTC however flashes up with the warning message to say the CF;s have been changed and to check them.
Any thoughts anyone?
Jerry
Re: OSTC Planner
Posted: 17 Jan 2015, 22:38
by Bardass
Re: OSTC Planner
Posted: 17 Jan 2015, 23:45
by Smiler1968
Thanks, I'll give that one a try in the morning.
Re: OSTC Planner
Posted: 18 Jan 2015, 11:11
by Smiler1968
Bardass Wrote:
> use this version
https://ostc-planner.net/wp/beta-2-90-5-goes-publi
> c/
That worked a treat. Thanks.
Re: OSTC Planner
Posted: 04 Jan 2016, 21:12
by WG
and Bardass' recommendation helped me as well!!
Walter
Belgium
Re: OSTC Planner
Posted: 09 Mar 2016, 20:41
by Smiler1968
Guys,
Sorry to resurrect such an old subject but I've come across another issue. The last time I updated my firmware was when I posted this. So initially I was able to upload the firmware but had problems reading / updating the CF's. I uploaded the version suggested and had no problems with the CF's. At that point I didn't recheck the firmware updates.
Now I have decided to move to 3.13 and attempted to update via OSTC Planner. I keep getting a message that it can't locate the chip ( or something similar). The OSTC shows Bootloader in red on the screen and then changes to Bootloader aborted. I can however do a screen dump and update the time and date.
I gave up and downloaded subsurface. That worked without issue.
Any thoughts?
Jerry.
Re: OSTC Planner
Posted: 15 Mar 2016, 14:26
by Smiler1968
Smiler1968 Wrote:
> Guys,
> updates.
> the time and date.
> without issue.
> Any thoughts?
> Jerry.
Ok has anyone on here updated firmware on a Mac using OSTC Planner recently? Did you have any issues. Am I right in thinking it can't be a driver issue as it is recognized as a com port and I can update CFs and screen dump. Would subsurface use the same drivers?
Any pointers would be appreciated. I have emailed OSTC Planner support but not heard anything back.
Regards.
Re: OSTC Planner
Posted: 15 Mar 2016, 16:44
by Bardass
Re: OSTC Planner
Posted: 15 Mar 2016, 18:35
by Smiler1968
Can you use companion to update firmware on an OSTC2n?
Re: OSTC Planner
Posted: 15 Mar 2016, 21:15
by Bardass
yes
Re: OSTC Planner
Posted: 16 Mar 2016, 08:35
by Smiler1968
Bardass Wrote:
> yes
OK I have just got home from work and have loaded OSTC Companion onto the Mac. The OSTC2n is recognised and I can change the name and date/time. However the Update firmware and set icon buttons are greyed out.....am I doing something wrong?
Jerry
Re: OSTC Planner
Posted: 16 Mar 2016, 20:07
by glance
You could always use Subsurface to both change settings and update the firmware.
Subsurface doesn't support changing all the settings on the OSTC, Mk.2/2N/2C , because they are so darn many, but the ones I have felt the need for is there.
//Anton
Re: OSTC Planner
Posted: 16 Mar 2016, 20:47
by Smiler1968
> need for is there.
> //Anton
I know I could and that is what I am doing at the moment. However the OSTC Planner was a one stop shop for everything I needed - and I supported the software by registering. It's frustrating that I can't get it to work.
As I said I think I'm right in that it's not the FTDI driver as it works with subsurface and I can screen print, adjust date and time and play around with the CF settings with Planner.
Re: OSTC Planner
Posted: 19 Mar 2016, 14:52
by Minke
Cant get mine to work either... Cant download CF`s.. Ceeps getting error message:Bad setpoint ppO2 = 0.4[bar]
Its on a MAC too.
Re: OSTC Planner
Posted: 19 Mar 2016, 15:04
by Minke
Edit..
Just tried it on a winblows machine and it is the same problem..
I really miss a program too edit my custom functions. Is there any other program to do this, other than ostc planner?
Re: OSTC Planner
Posted: 20 Mar 2016, 03:39
by divinglog
Re: OSTC Planner
Posted: 26 Apr 2016, 19:44
by Lee Chenyu
anybady knew why edit CF is ok ,but Uploading OSTC configuration is failed?
Re: OSTC Planner
Posted: 29 May 2016, 14:10
by Minke
Thats only for winblows...
Re: OSTC Planner
Posted: 31 May 2016, 16:56
by kaheksa
I have this on the right side of OSTC Planner 2.90.5
QSslSocket: cannot resolve TLSv1_1_client_method
QSslSocket: cannot resolve TLSv1_2_client_method
QSslSocket: cannot resolve TLSv1_1_server_method
QSslSocket: cannot resolve TLSv1_2_server_method
what is it about?
