New 3.02 Firmware
Posted: 05 Feb 2015, 13:32
Today, we released the 3.02 stable for the OSTC2 Series (2N/Mk.2/2C). It includes a few smaller fixes and changes.
Updating is very easy if you have 1.90 or later and using Windows.
1. Get new bootloader v2:
http://www.heinrichsweikamp.com/?id=145&version=en
2. Follow the step-by-step instructions:
http://www.heinrichsweikamp.com/?id=117&version=en
Heute haben wir die Version 3.02 stable für die OSTC2 Serie (2N/Mk.2/2C) veröffentlicht. Sie beinhaltet einige kleinere Verbesserungen und Fixes.
Das Updaten auf die neue Version ist sehr einfach, wenn bereits 1.90 oder später installiert ist und Windows verwendet wird.
1. Neuen bootloader v2 herunterladen:
http://www.heinrichsweikamp.com/?id=145&version=de
2. Die einfache Schritt-für-Schritt Anleitung befolgen:
http://www.heinrichsweikamp.com/?id=117&version=de
Viele Grüße/Best Regards,
Re: New 3.01 Firmware
Posted: 05 Feb 2015, 15:00
by jb2cool
Is there a changelog?
Posted: 05 Feb 2015, 15:23
A normal one:
http://www.heinrichsweikamp.com/?id=57
A detailed one:
https://bitbucket.org/heinrichsweikamp/ ... ommits/all
Posted: 05 Feb 2015, 16:00
by jb2cool
Many thanks. Was just wondering how excited i should get about this.
Posted: 06 Feb 2015, 00:27
by Damienbt
Any changes of significant note?
Posted: 06 Feb 2015, 09:55
Look in the changelog and decide for yourself
New in 3.01:
Stable Release
BUGFIX: Entry time in logbook when dive was around midnight
BUGFIX: Show manually set O2 (Gas 6) correctly
BUGFIX: Show dives with >999mins divetime correctly
Re: New 3.02 Firmware
Posted: 07 Feb 2015, 12:47
Hi there,
There was a minor layout issue with the divetime in the 3.01 (Too bad I didn't see this before posting the 3.01...) This is now fixed in the 3.02.
Posted: 08 Feb 2015, 05:18
by Clownfish
Also, all Custom Functions III seem to reset to the default, so check before you dive.
Posted: 08 Feb 2015, 15:49
by ROB61
I can confirm CLOWNFISHs statement.
All my personal changes in CFIII where reset to default!
So be carefull.
ROB
Posted: 09 Feb 2015, 10:50
by zbenu
Hallo
Kann mir jemand erklären was genau Ceiling new ab FW 3.0 bedeutet oder wie ich das beim Tauchen imprtieren muss, gibts da eine Beschreibung.
Besten Dank Benu
Posted: 09 Feb 2015, 12:34
by jb2cool
Check your dates too. Mine has reset to 2000. This might have been caused by a bad 'sync time with PC' though.
Posted: 09 Feb 2015, 21:44
by sailor
Ceiling ist die eigentlich erforderliche stufenlose Deko-Tiefe, die mindestens einzuhalten ist.
Die 3-Meter Schritte konventioneller Deko-Anzeigen sind nur eine gestufte Anzeige der Ceiling.
Wenn die Ceiling grob zwischen 6 und 3 Metern liegt, wird als Dekostufe 6 Meter angezeigt, wenn sie grob zwischen 3 und 0 Metern liegt wird 3 Meter als Dekostufe angezeigt.
Die Ceiling nimmt stufenlos ab vom tiefsten Dekostop bis zur Oberfläche, wobei die Geschwindigkeit der Abnahme immer geringer wird je flacher die Ceiling ist.
Wenn die Ceiling 0 Meter erreicht ist die Deko beendet.
Posted: 25 Feb 2015, 15:08
Ceiling is always computed with the GF_hi. That means the ceiling can be above 3m and still a 6m stop is shown (Which is based on a lower GF then GF high).
Posted: 30 Mar 2015, 08:00
by Rob
Nur kurze Info:
Firmware 3.02 nach Update von 3.00.
Ich bin nach dem Update in das Logbuch gegangen, ersten Tauchgang der Liste ausgewählt und auf der ersten Logbuch-Seite in der ersten Zeile stand ganz rechts eine -1. Nur beim ersten Tauchgang.
Nach ein wenig rumspielen mit dem Logbuch war die -1 dann verschwunden. Was genau zum Verschwinden geführt hat kann ich nicht sagen.
Grüße
Posted: 30 Mar 2015, 11:48
Hallo Rob,
Ja, ist ein Bug und in der 3.03 behoben.
Die "-1" soll anzeigen, das der TG über Mitternacht hinaus ging, das TG-Datum also um einen Tag falsch ist.
Posted: 10 Apr 2015, 17:47
by Dahab Boris
Mine upgraded fine, no problems
Posted: 15 Apr 2015, 11:55
by steficic
with the new FW 3.02, I have the issue with the Logbook (OSTC 2C).
The first time I get into the Logbook, on the top is missing the first row (with #, date and time). If I get out of that dive and in again, it's OK: see attachments.
BS
Posted: 15 Apr 2015, 11:56
Thanks for the post - this has already been fixed for the 3.03.
Posted: 02 May 2015, 16:30
by kaheksa
I think I have a bug to report
Charged the OSTC overnight and the battery was green with the charger still connected. But in the battery info it doesnt show a full charge and the minute counter didnt get a reset.
Charger output - 5.1V 0.7A
v3.02
Posted: 02 May 2015, 19:08
by khagse
Hi
Aktuellste Doku der Custom Functions immer noch V2.94 beta?
Grüsse
André
Posted: 04 May 2015, 13:57
khagse Wrote:
> Hi
> V2.94 beta?
Ja, keine Neuen CF seitdem.
Posted: 04 May 2015, 13:59
