I have two problems with my OSTC Sport.
Those problems seems to have appeared after firmware update to v 10.14, as I didn't notice any problem before that.
1 - Battery drain.
After using my OSTC sport for 3 months, with very reasonable battery consumption, I updated to v10.14 end of february ( just after firmware release). On march 8th, before the dive, I check my computer and notice the battery is dead. So I dive with my back-up computer. In the evening, I replace the battery with a brand new AA alkaline one and the OSTC Sport starts fine.
Today march 29th, on the dive site, and with no dive since I changed the battery, the screen shows only 54% remaining. And tonight as I write this message, only 39% remaining.
2 - BT connection unsuccessful
After noticing this abnormal (I think) battery drain, I wanted to try restoring a previous version firmware, just to check if this was linked to v10.14.
I selected BT in the OSTC menu as usual, but my OSTC is not visible by my Macbook. I checked with 2 other computers, MAC & PC : impossible to pair with the OSTC via BT. I tried restoring OSTC parameters to factory defaults, same issue.
Has someone experienced similar problems after firmware upgrade ?
Any idea to help me solve this ?
Thanks for your help !
OSTC Sport - BT won't connect and battery drain
OSTC Sport v10.17
OSTC Companion v1.134
Mac OSX 10.7.5
OSTC Sport v10.17
Mac OSX 10.7.5
Re: OSTC Sport - BT won't connect and battery drain
This looks like a battery issue.
Current consumption of the 10.14 in sleep mode in the sport is ~200µA@1,5V, meaning a quality battery like the Energizer 1,5V E2 AA (Which was the reference battery for the 1,5V tests, 3000mAh) lasts ~2 years in St.By. Also, the battery percent-display was calibrated for this battery. It may be wrong for others.
Another issue with 1,5V batteries is that the bluetooth requires quite a lot of current from 1,5V batteries. ~200mA of peak current and the input voltage must be >1,1V while bluetooth is active.
I assume the bluetooth chipset is starting, the battery voltage drops and the OSTC disables the bluetooth chipset automatically.
-> Please try with a different (quality) battery if this issue continues.
Thanks for your answer.
The battery currently in my OSCT Sport is a Duracell Simply AA 1,5V, maybe not the best I admit, but this is what I had available for tests.
Anyway, I had previously a SAFT LS14500 AA 3,6V, the one supplied with my OSTC. From november 2014 (purchase) to firmware update end of february 2015, the battery level dropped from 100% to ~84%. After the firmware update and until march 8th, in sleep mode only, it dropped from ~84% to 0%. Then I put a brand new Duracell AA 1,5V, and from march 8th to march 29th, in sleep mode only, it dropped from 100% to 54%.
I'll give a try tonight with a new battery to check if I can connect via bluetooth. I'll let you know the result.
Cédric.
Cédric.
OSTC Sport v10.17
Mac OSX 10.7.5
OSTC Sport v10.17
Mac OSX 10.7.5
Also update to the latest 10.15 (released today). I also verified sleep mode and operation current consumption for this release.
Sure, I'll update to 10.15 too.
Cédric.
Cédric.
OSTC Sport v10.17
Mac OSX 10.7.5
OSTC Sport v10.17
Mac OSX 10.7.5
New test tonight with a new Duracell simply AA 1,5V battery (twin sister of the previous one).
Battery indicator 100% 1,5V. The OSTC sport is immediately detected by the macbook bluetooth.
For information, it didn't work with the previous one showing 39% and 1,3V on the battery indicator.
I immediately upgraded the firmware to 10.15. Thanks for the improvements (compass and GF settings), by the way.
I now have to wait and check for battery life and consumption back to something normal.
Thanks for your help.
OSTC Sport v10.17
Mac OSX 10.7.5
OSTC Sport v10.17
Mac OSX 10.7.5
