subsurface
Posted: 23 Jun 2015, 14:03
by ScubaScubaDoo
Hi All,
Can't import dives from my OSTC sport to subsurface, download starts okay but after a few minutes i get a error message, 'DIVE DATA IMPORT ERROR' which I'm not able to fix.
Has anyone had the same problem and how was this resoled.
Mac computer, software MAC OS X Lion 10.7.5
Any help welcome
Graham
Re: subsurface
Posted: 23 Jun 2015, 15:08
Hi Graham,
Which version is running on the OSTC Sport? If it's 10.16 then this is a known issue and an update to the latest version will fix this.
Re: subsurface
Posted: 23 Jun 2015, 16:03
by ScubaScubaDoo
Running on version 10.18
This has been a probloem for me sins I've downloaded subsurface,
Ive just updated subsurface to 4.4.2 but hasn't help with this issue.
Graham
Re: subsurface
Posted: 26 Jun 2015, 13:44
by ScubaScubaDoo
Still waiting for replay to above post.
Running on version 10.18 and Ive just updated subsurface to 4.4.2 but hasn't help with my issue.
Graham
Re: subsurface
Posted: 26 Jun 2015, 13:52
I've seen your post, but I can't help you here, sorry. Maybe you can post the "libdivecomputer protocol file" here? You have to enable the protocol file before downloading.
Re: subsurface
Posted: 26 Jun 2015, 16:20
by divejy
Can you try unpair mac and your sport, pair again.
I hv this experience once
Re: subsurface
Posted: 26 Jun 2015, 17:17
by glance
Save a log file of your download and attach it here. Its the best way to debug such errors.
There's a checkbox in the Download dialog for creating a logfile.
Re: subsurface
Posted: 26 Jun 2015, 17:37
by ScubaScubaDoo
Thank have attached file
Re: subsurface
Posted: 26 Jun 2015, 17:47
Re-pairing the unit might indeed help here...
Re: subsurface
by glance
It basically:
Subsurface: "Hi!"
Device: "Bye!"
I'd test to re-pair your bluetooth connection and try again.
One thing i've seen is that when your battery is running a bit low you might get problems communicating over bluetooth, but the computer in general runs just fine. Try with a fresh battery to.
//Anton
Re: subsurface
Posted: 26 Jun 2015, 18:26
by ScubaScubaDoo
Hi All,
Tried deleting device and I've repaired OSTC Sport still not working, when i try to download from dive computer same error.
Battery is at 76% but i will try a new one.
Ive had this problem with subsurface sins I've downloaded this program, companion works great with bluetooth i don't think this is a bluetooth problem.
Graham
Re: subsurface
Posted: 27 Jun 2015, 18:58
by finger
Delete device and repair AGAIN...this surely will help sooner or later...
Re: subsurface
Posted: 28 Jun 2015, 08:53
by screech
Hi , dive log is downloadable with 10.17 soft but unable with 10.18 same error that occur with 10.16 version .
Re: subsurface
Posted: 28 Jun 2015, 11:37
Please check the dives in the internal logbook. Are there still dives with "10.16" firmware stored?
Re: subsurface
Posted: 28 Jun 2015, 11:47
by ScubaScubaDoo
Hi Matthies,
No theres not 10.15, 10.17, 10.18 no 10.16 dives stored.
Did my posting of subsurface.log help
Graham
Re: subsurface
Posted: 28 Jun 2015, 11:50
> stored.
That this has nothing to do with the (well understood) 10.16 download issue.
No, it only shows that there is no reaction from the OSTC to the Subsurface command.
But the information that it works with the 10.17 might give a clue where to search (Communication timeouts). Unfortunately I can't reproduce this error here (On MAC or Windows) at all.
Re: subsurface
Posted: 29 Jun 2015, 08:46
by ScubaScubaDoo
It doesn't work on 10.17, as I've said its not worked sins I've downloaded this program.
Will try another software program
Graham
Re: subsurface
Posted: 29 Jun 2015, 12:02
Hi Graham,
That was a response to user "screech".
