Dev for OSTC
Posted: 04 Jul 2015, 09:31
Few questions about developing for the OSTC / hwOS. Great looking computer btw and thanks for making it open source, you guys rock!
Managed to get everything build with a bit of patience. The Fonts/Icons .inc paths seemed to prove the hardest problem. You might want to update the docs on that.
* Were you so limited on memory that the code needed to be in assembler? I'm new to embedded development, so this seems excessive to me. C isn't that much bigger. I assume this wasn't just a style thing?
* Is there any emulation available to test on? Obviously MPLab has as simulator, but without the screen and sensors, it seems a bit pointless, unless running the test suites.
* Is there any development hardware available? Or different rates for developers? I'm keen to try out some ideas and while I would like a model myself, I would like one exclusively for dev also.
* Is the Sport identical hardware OSTC3? I was wondering if the difference was simply the software installed on it. This is just from looking at the photos, so excuse my ignorance on this.
Anyway, keep up the good work.
James.
James.
