Page 1 of 2
download logbook over Bluetooth
Posted: 28 Jul 2015, 18:51
by varaktor
I do have the new OSTC2 and was trying to download the logbook data over BT. I tried it on a Windows7 PC with BT dongle and on a Samsung Smartphone running Android 4.4.2
With the new OSTC companion (1.200) I can connect to it on the PC without a problem (and set eg. time and date)
With Diving Log 6.0 or Subsurface it doesn't work on the PC and with Divemate on the Smartphone:
Subsurface error message:
Unzureichende Privilegien zum Öffnen von Gerät COM16 Heinrichs Weikamp (OSTC2)
doesn't show download mode enabled on OSTC
Diving Log 6.0 Error Message:
OSTC 2 nicht gefunden, bitte überprüfen ob er angeschlossen oder eingeschalltet ist (DC_STATUS_TIMEOUT)
download mode enabled is shown on the OSTC
Divemate on Android phone:
Download mode enabled is shown on OSTC
progressbar goes to 81% and stops than until it goes into timeout
What am I doing wrong?
Thanks for your help
Uli
Re: download logbook over Bluetooth
Posted: 29 Jul 2015, 12:18
Hallo Uli,
Make sure to select the "OSTC 2", not OSTC 2N/2C or Mk.2. Bluetooth must be enabled manually in the OSTC in order to download.
Posted: 03 Aug 2015, 18:35
by Mike R
I've also got problems downloading. I'm using a Bluetooth dongle, have upgraded to Dive Log 6, have downloaded FTDI driver, have selected OSTC 2. I appear to have a bluetooth connection to the computer, and the OSTC 2 seems to connect briefly to Dive Log 6 via COM port 6 but then disconnects and reports that it has timed out.
Any thoughts?
Mike R
Posted: 03 Aug 2015, 18:50
Hi Mike,
You do not need to install the FTDI driver (Only required for USB OSTC's). Are the OSTC2 and the system paired? "I appear to have a bluetooth connection" - check system settings -> Devices. Is the OSTC2 visible there and which com-port has been assigned (Right-Click -> Preferences)?
Posted: 07 Aug 2015, 18:31
by Mike R
Thanks Matthias,
I have attached some screen prints. As far as I can see the OSTC and the computer are paired and COM port 6 has been assigned.
Mike
Posted: 10 Aug 2015, 12:10
Do you have the bluetooth mode enabled (In the OSTC 2) when trying to downlaod?
Your configuration and settings look ok.
Posted: 13 Aug 2015, 14:29
by Mike R
I believe so - I hit the Bluetooth option and it responds - then it times out after a few minutes. While it seems to be enabled I can see an indication on the Bluetooth screen on the laptop that there is a connection.
I tried to download like that numerous times. Then I tried on the OSTC 2 coming out of its Bluetooth screen to go to the Logbook menu, in case that is necessary - but that just seems to close the connection.
Mike
Posted: 16 Aug 2015, 21:25
Hi Mike,
The OSTC enables Bluetooth in the Bluetooth mode only. Try the following: make sure to start the apps with Administrator mode. Keep the distance quite short. Do one step after the other (Pair the device, start the App, start downloading).
Posted: 17 Aug 2015, 15:28
by Mike R
OK - have tried the order you suggested and opened the app (Dive Log 6) in administrator mode. I am getting the attached error report on the laptop computer. Everything else checks out ok - COM6 / OSTC 2 etc.
On the OSTC there is now a line under the Bluetooth button that says "Download mode enabled". That looks promising, but after that it still sends the attached error report and then the OSTC disconnects. It's as if there's a connection established but nothing is heard back from the OSTC and therefore something times out.
I note that the serial port connection (COM6) is defined on the laptop as Outgoing whereas COM4 and COM5 are defined as Incoming - not sure if that makes a difference. I've tried removing the COM6 connection and then re-establishing it - no difference!
I appreciate this is difficult to solve remotely, but I do appreciate your continuing support and advice.
Mike
Posted: 17 Aug 2015, 18:32
by Henrik S
Hi!
I am so pissed off now of the problem of getting the OSTC2 to speak with my PC Win10 that I am close to throwing the computer right at the wall...
My Dell laptop identifies the OSTC2 in Bluetooth settings. It adresses a COM-port.
This both with the built in and external Bluetooth adapter.
None of the programs OSTC Companion, OSTC Tools, Subsurface or Divelog will connect and download from the OSTC2. Tried several COM-ports
Had the same problem with Win7. Worked with Win8.1 and now it's fucked up with Win10
:X
Posted: 18 Aug 2015, 10:44
There is the option: Log Errors behind "Advanced Settings". That would help a lot.
Posted: 18 Aug 2015, 11:02
by Mike R
Matthias,
I have successfully upgraded the firmware of the OSTC2 via OSTC Companion - and using the Bluetooth connection, obviously. So I guess that confirms the connection is good. However, the download of dive data to Diving Log 6 is showing the same error as before!
Does that give any more clues?
Mike
Posted: 18 Aug 2015, 11:38
Please enable the error log and post it here. No screenshot please, the whole log file which will be created if you enable the option: "Log Errors" behind "Advanced Settings"...
Posted: 18 Aug 2015, 11:46
by Mike R
Error Log
System.Reflection.TargetInvocationException: An exception occurred during the operation, making the result invalid. Check InnerException for exception details.
at System.ComponentModel.AsyncCompletedEventArgs.RaiseExceptionIfNecessary()
at Divinglog.Download.Libdivecomputer.BWorker_RunWorkerCompleted(Object sender, RunWorkerCompletedEventArgs e)
at System.ComponentModel.BackgroundWorker.OnRunWorkerCompleted(RunWorkerCompletedEventArgs e)
at System.ComponentModel.BackgroundWorker.AsyncOperationCompleted(Object arg)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
System.InvalidOperationException: Internal error in newly produced path figures.
at System.Windows.Media.PathGeometry.FigureList.AddFigureToList(Boolean isFilled, Boolean isClosed, MilPoint2F* pPoints, UInt32 pointCount, Byte* pSegTypes, UInt32 segmentCount)
at Divinglog.Download.Libdivecomputer.dc_device_open(IntPtr& device, IntPtr context, IntPtr descriptor, String name)
at Divinglog.Download.Libdivecomputer.DLUniversal(LibdivecomputerDescriptor Desc)
at Divinglog.Download.Libdivecomputer.BWorker_DoWork(Object sender, DoWorkEventArgs e)
at System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument)
Posted: 18 Aug 2015, 11:53
by Mike R
Just did it again and got this
INFO: Open: name=COM6
INFO: Configure: baudrate=115200, databits=8, parity=0, stopbits=1, flowcontrol=0
INFO: Timeout: value=3000
INFO: Sleep: value=300
INFO: Flush: queue=3, input=0, output=0
INFO: Write: size=1, data=BB
INFO: Read: size=1, data=BB
INFO: Read: size=1, data=4D
INFO: Write: size=1, data=69
INFO: Read: size=1, data=69
INFO: Read: size=64, data=9A2701564D696B652052204F53544332203200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
INFO: Write: size=1, data=6A
INFO: Read: size=1, data=6A
INFO: Read: size=1, data=11
INFO: Write: size=1, data=61
INFO: Read: size=1, data=61
INFO: Read: size=306, data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
ERROR: Failed to receive the answer. [in hw_ostc3.c:218 (hw_ostc3_transfer)]
ERROR: Failed to read the header. [in hw_ostc3.c:550 (hw_ostc3_device_foreach)]
INFO: libdivecomputer-0.dll version: 0.5.0-develINFO: Write: size=1, data=FF
INFO: Read: size=1, data=B0
ERROR: Unexpected echo. [in hw_ostc3.c:186 (hw_ostc3_transfer)]
ERROR: Failed to send the command. [in hw_ostc3.c:410 (hw_ostc3_device_close)]
Posted: 18 Aug 2015, 18:56
by Henrik S
INFO: Open: name=COM19
ERROR: Det gick inte att hitta elementet (1168) [in serial_win32.c:152 (serial_open)]
ERROR: Failed to open the serial port. [in hw_ostc3.c:275 (hw_ostc3_device_open)]
Posted: 18 Aug 2015, 20:36
by TnT
> 00000150000000151
A timeout while reading the dive headers. Maybe the bluetooth connection got disconnected? Can you retry to check whether this was just an occasional error or not?
Jef
Posted: 18 Aug 2015, 20:46
by TnT
The windows error code 1168 is ERROR_NOT_FOUND. So I guess you're trying to use a serial port which does not exist.
Jef
Posted: 18 Aug 2015, 23:11
by Mike R
Will do - I've tried it scores of times of course but just now have copied the error log a couple of times. Hope this helps!
INFO: Read: size=328, data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
INFO: Read: size=1, data=00
AND AGAIN:
System.NullReferenceException: Object reference not set to an instance of an object.
at Divinglog.Download.Libdivecomputer.dc_device_foreach(IntPtr device, dive_callback callback, IntPtr userdata)
Diving Log Version: 6.0.0.1
Windows Version: Windows 8.1
AND AGAIN:
Did something a bit different the last two times - not seen that before - a different error report window.
That's what I've got.
Mike
Posted: 18 Aug 2015, 23:13
by Mike R
And again:
INFO: Read: size=0, data=
ERROR: Failed to receive the echo. [in hw_ostc3.c:176 (hw_ostc3_transfer)]
ERROR: Failed to send the command. [in hw_ostc3.c:318 (hw_ostc3_device_init_download)]
Mike
Posted: 19 Aug 2015, 16:19
by divinglog
Hi Mike
The 2 errors:
are a problem within Diving Log, not libdivecomputer. I'm currently looking into this issue.
But I don't think they are causing the download interruption:
So there are acutually 2 different issues.
Posted: 19 Aug 2015, 16:24
As for the timeouts: Increasing the thread priority (Windows Task Manager) for the OSTCCompanion.exe should also help. Especially on older PCs. This was just reported via mail from one of the forum users here.
Posted: 19 Aug 2015, 16:59
by TnT
For this problem, I would like to test a build with a longer timeout. But that will have to wait until tomorrow. I'm too busy right now.
Jef
Posted: 19 Aug 2015, 17:02
by Mike R
Many thanks guys - tell me when you need me to try anything - otherwise I'll leave it with you experts.
Mike
Posted: 19 Aug 2015, 17:06
by Mike R
By the way - the laptop I'm using is an HP Ultrabook just over a year old.
Mike
