hwOS for OSTC3, cR and OSTC 2: New 1.88 released
Posted: 12 Aug 2015, 12:05
The new OSTC3, cR and OSTC 2 firmware 1.88 is now available for download: http://www.heinrichsweikamp.com/?id=479&version=de (German) or http://www.heinrichsweikamp.com/?id=479&version=en (English)
The firmware itself can be set to English, Deutsch, Italiano and Français.
New since 1.81:
BUGFIX: Start with sensor use from sleep (cR only)
CHANGE: Apply button settings when button menu is closed
NEW: Reset button settings on a magnet reset (cR and OSTC 2)
NEW: Hardware support (Screen)
NEW: Additional temperature calibration via PC interface
CHANGE: French update
BUGFIX: Rotate button sensitivity with screen (OSTC 2 and cR)
CHANGE: GF and aGF high range increased to 45-110%
NEW: New option to download "Compact Headers". Improved BLE support (OSTC 2 and OSTC 3+)
NEW: Quit Simulator automatically when starting a real dive
BUGFIX: Auto-Brightness clipped to lowest settings in bright sunlight on some devices
CHANGE: Auto SP now available on OSTC 2
CHANGE: change button sensitivity range and default (OSTC2 and cR)
NEW: MOD Warning (Can be disabled)
NEW: Depth dependent ascend speed (Can be disabled)
NEW: Graphical speed indicator (Can be disabled)
NEW: Option to always show the ppO2, shows ppO2 for Diluent in CC mode
NEW: Mode Auto SP: Automatically switches the SP during descent (CC Mode)
NEW: Deco planer computes gas consumption for all gases and can compute bailout plans for CC modes
Details on the new hwOS: http://www.heinrichsweikamp.com/?id=335
Re: hwOS for OSTC3, cR and OSTC 2: New 1.88 released
Posted: 07 Oct 2015, 16:03
by Eddy
How do I make active the compass, to go into the water. what actions should I do? I do a simulation, the compass comes up, but also fall out again. I can print to that haeding comes, but so what?
Posted: 08 Oct 2015, 06:51
by netway
[quote=heinrichsweikamp]
Wie sind die beiden Punkte zu verstehen? oder wofür brauche ich diese Funktionen?
Posted: 08 Oct 2015, 12:27
> interface
> [/quote]
Das erste Betrifft interne Änderungen in der Hardware (Unterstützung für einen anderen Display-Treiber) und das zweite ist quasi eine Custom Function um die Temperatur-Messung zu kalibrieren.
Posted: 09 Oct 2015, 13:01
Continue here: read.php?6,15778
