OSTC Sport MARES NEMO WIDE
jp01000
Post by jp01000 »
I dive with my wife using a MARES NEMO WIDE.
What settings do you recommend for fairly similar decompression?
fyb
Re: OSTC Sport MARES NEMO WIDE
Post by fyb »
this question is better asked to Mares - because the OSTCs are open source computers - it is clear what OSTC does ... but Mares???
anyway i dive normaly GF 40/80 and my friend uses a Mares Icon HD black edition (i do hate this display layout) and we usually have about the same TTS on regular air dives to app. 45m
jp01000
Post by jp01000 »
Thank you
which decompression model?
Motardplongeur
Post by Motardplongeur »
Hi
Some information after 4 dives (Marseille, last week end) with my Sport (10.19) and a Nemo Wide (first model, last software "3 gases") :
All dives in two days, from 45 to 62 mn, temperature between 18°C & 15°C, max depth from 30 to 36 m, average depth between 17 & 22 m ; air.
Nemo Wide at the lowest level of conservatism.
Sport with Bülhmann (w/o GF) and last deco 4 m
2 dives made with "conservatism +0" (112/88 %):
=> max deco displayed on the NW : 7 mn
=> max deco displayed on Sport : 3 mn
Real deco : 2 mn on Sport & 7 on NW (not "real" time but displayed time at 4 m ; i did not check real time, knowing deco at 4 m for NM gives (very) longer minuts !)
2 dives made with "conservatism +1" (115/85 %) :
=> max deco displayed on Sport : 6 mn
Real deco : 4 mn on Sport & 5 on NW (same remarks as above)
2 buddies with Suunto Stinger or Vyper : deco duration + 5 ou 6 mn compared to Sport.
I'll try to show curves time/depth/deco while free time.
[EDIT] : Sport's conservatism modified, sorry I made a mistake
OSTC #12002 & #11150
Motardplongeur
Hi
After 5 new dives (Cavalairen this WE) between 32 & 52 m (45 to 25 mn, 20°C), I confirm that "+1 conservatism" (115/85 %) on the Sport gives approx same results as my Nemo Wide from a deco point of vue.
