Hi
I cannot turn on my OSTC. If I plug the interface into my laptop and into the OSTC then press the reset button it will turn the OSTC on. I get the normal screen display for approx 1 minute then the screen says "Please wait, rebuilding MD02 hash" the OSTC then turns off again.
The battery is fully charged so it is not that.
Gareth
Cannot turn on
Re: Cannot turn on
When the unit is on (After your reset procedure), can you use both buttons fine?
To turn on, both buttons must be pressed for about 2 seconds.
Re: Cannot turn on
The left button works when the unit is plugged into my laptop, however the right button fails to enter the menu. So I think it is broken.
Gareth
Gareth
Re: Cannot turn on
To enter the menu first press left, then right. Make sure to fully press the buttons. They are quite stiff.
Re: Cannot turn on
Matthias,
I've had it since January, the buttons have been fine up till now. The unit will not turn on by holding the buttons for any period of time. The only way to get it to turn on is to plug in the interface connect to my laptop, press reset button, then the unit turns on.
The left button for the menu works, when I press that I get the enter menu option, however when I press the Right button nothing happens, no matter how soft or hard I push it.
When I get home again next month I will send it to you to see.
Gareth
Gareth
