Mathias, are you aware of a strap that could be used with or even instead of the bungee. Something like the nato type straps?
I do have one of these fitted and it works well but I cannot find anything long enough to wear with a drysuit, any ideas (anyone)?
Pete
Strap with bungee
Re: Strap with bungee
Hello Pete,
you mean something like this?
http://shop.heinrichsweikamp.com/zubeho ... m_store=de
Cheers, Igor
Cheers, Igor
Thanks but no. What I actually meant was a 'watch strap' to use with the existing bungee - as a security bungee.
The strap needs to be approx 40 cms long and be the NATO style of approx 2 cms wide, then it would fit under the backplate and be long enough to fit over a drysuit.
Try www.gasgasbones.com. Lengthwise they should be able to make them in any size you want.
