Hi Mark
I usw Dive Log by Greg McLaughlin
https://appsto.re/at/aCA8r.i
In the AppStore (Hope the Link works) is Version 2.1.4 which can't read OTSC.
I got the 2.2 Beta and meanwhile the prerelease.
Re: Dive Log for iOS
Mark Rowe
Re: Divemate für iOS
Thanks for the info - so version 2.2 of Dive Log on iOS will read the OSTC?
Mst
It reads the sport with the black knobs and serial number above 12,000.
OTSC 2 & 3 need firmware 10.19 or higher.
Only I can't tell you when the final version 2.2 will be in the App Store.
Currently, as I understand it, the Prerelease is available for beta-testers.
For the moment I would just download the current version and try it out to see if you like it. And if you do just wait a little for the update.
If you make dives before final 2.2 gets rolled out it is no problem, because you can log these dives normally by hand and import the profiles of those dives later and merge them into the existing logbook entries.
Kind regards Martin
Kind regards Martin
