Manual setpoint change problem
Posted: 26 Oct 2015, 19:25
by Jonny H
I have the OSTC Mk2; having just upgraded to latest stable v3.10 and setting auto set point change auto. When I manually change from set point 1 to set point 2 in the simulator then the diluent automatically changes to 32/0. I then have to change the diluent back to air throgh the menu page.
My set up is as follows, all diluents set to air. Diluent 1 set active.
Gas menu is gas 1,3,4 and 5 set to air; gas 2 set to 40/0. Gas 1 is first gas active, all other gasses set not active.
Is this a bug or intended operation and if intended why?
Thanks in advance
John
Re: Manual setpoint change problem
Posted: 26 Oct 2015, 19:31
by Jonny H
Additional info:
I re-flashed my OSTC with v3.02 software and the situation as desribed in post 1 does not happen; ie, when I manually change from set point 1 to 2 and 3 the diluent remains the same and does not auto change to 32/0.
John
Posted: 27 Oct 2015, 18:54
Hi John,
Thanks for reporting - I'll investigate this issue tomorrow.
Posted: 28 Oct 2015, 13:55
I can confirm this bug. It's indeed a serious issue for CCR divers (Well, at least you can see that the wrong diluent is chosen).
Sorry for that.
I'll upload the 3.11 with this issue fixed today.
Posted: 28 Oct 2015, 15:58
Have some issues with our firmware section on the webpage currently, but here's the 3.11:
read.php?2,15834 And it's also available via the "Web Download" in the Tinybootloader v2.
Posted: 29 Oct 2015, 19:23
by Jonny H
Matthias,
I can confirm that software v3.11 no longer has the issues described at post 1. Many thanks for the quick fix.
John
