OSTC3 FW V1.92 Logbook Download fails
Posted: 14 Nov 2015, 20:02
by BerndE
Recently I updated my OSTC3 from FW Version 1.86 to V1.92.
I did a dive that is completely stored in the OSTC3 and I get all the details in its logbook.
Unfortunately downloading this latest dive with Diving Log 5.0 permanently fails
This last dive (FW V1.92) is not seen by Diving Log 5.0 whereas all previous dives (FW V1.86) are.
Any help available?
Re: OSTC3 FW V1.92 Logbook Download fails
Posted: 15 Nov 2015, 04:23
by divinglog
Hi, you need either
Diving Log 6.0 or download and extract the latest
libdivecomputer into the Diving Log 5.0 program folder.
Posted: 17 Nov 2015, 18:38
by BerndE
With the latest "libdivecomputer-0.dll" an exception error dialog opens
Sorry, error text is in German only:
Die DLL "libdivecomputer-0.dll": Die angegebene Prozedur wurde nicht gefunden. (Ausnahme von HRESULT: 0x8007007F) kann nicht geladen werden.
So I restored the previous lib. The exception error dialog does not appear. Diving Log 5.0 still does not see my last dive.
@ divinglog()
something wrong with the new lib?
I restored FW V1.86 to my OSTC3.
My last dive is in its logbook, but Diving Log 5.0 still does not see my last dive.
@ heinrichsweikamp
was macht V1.92 beim Logbook anders als die V1.86?
Posted: 17 Nov 2015, 19:10
by divinglog
[quote]With the latest "libdivecomputer-0.dll" an exception error dialog opens
Die DLL "libdivecomputer-0.dll": Die angegebene Prozedur wurde nicht gefunden. (Ausnahme von HRESULT: 0x8007007F) kann nicht geladen werden. [/quote]
Du musst auch die neue libusb-1.0.dll aus dem obigen Link in den Diving Log Ordner kopieren (vorher die alten sichern). Ich hab die neueste libdivecomputer nicht mit Diving Log 5.0 getestet, es sollte aber funktionieren. Die Firmware 1.92 braucht definitiv die neue libdivecomputer.
Posted: 17 Nov 2015, 19:36
by BerndE
Ich habe die "libusb-1.0.dll" kopiert und FW V1.92 geladen.
Diving Log 5.0 funktioniert wieder ohne Fehlerdialog
Aber der letzte Tauchgang wird weiterhin nicht gesehen und daher nicht runter geladen
Posted: 17 Nov 2015, 22:07
by divinglog
Hast du auch die neueste libdivecomputer geladen? Du brauchst die neueste libdivecomputer und libusb. Ansonsten probiere bitte mal Diving Log 6.0
Posted: 17 Nov 2015, 22:26
by BerndE
Uups, sorry, durch die ganzen Versuche und Hin- und Her-Kopierereien hatte ich wieder die alte libdivecomputer geladen.
Mit den beiden neuen Libs geht's jetzt.
Diving Log 5.0 hat meinen letzten TG korrekt erkannt und runtergeladen
Danke!
