hwOS for OSTC3, cR and OSTC 2: 2.01 released
Posted: 11 Jan 2016, 10:41
[Updated for 2.01 release]
The new OSTC3, cR and OSTC 2 firmware 2.01 is now available for download: http://www.heinrichsweikamp.com/?id=479&version=de (German) or http://www.heinrichsweikamp.com/?id=479&version=en (English)
The firmware itself can be set to English, Deutsch, Italiano and Français.
New since 1.90 (Blue for changes since 1.93):
BUGFIX: Divetime >99mins was not displayed (Only OSTC2 with serial > 10500)
BUGFIX: Minor layout fixes in divemode (Dynamic gaslist and stopwatch)
BUGFIX: Minor language updates
NEW: Logbook marker can be set in dive mode menu (OC only)
NEW: "Lost Gas" feature allows disabling gases during the dive
CHANGE: Show velocity from 5m/min or more (Ascend or descent)
BUGFIX: Make sure SP1 is always selected on start in Auto-SP mode
CHANGE: New segmented speed graph in divemode
BUGFIX: minor text allignment in CCR mode
CHANGE: fix timing issues during Bluetooth download (Bluetooth models only)
CHANGE: Logbook now shows end-of-dive date and time for dives made with firmware =1.92
BUGFIX: German texts in ppo2 menu were too long for screen resulting in resulting in text display issues
CHANGE: Do not show ppO2 in warning area if already shown in custom view
BUGFIX: Logbook list view for more then 100 stored dives
CHANGE: minor language updates
Details on hwOS: http://www.heinrichsweikamp.com/?id=335
Btw., Subsurface will automatically prompt for an update making the process very comfortable and available for many platforms (like old 32bit Systems).
We also did major updates to the manuals! They are available here: http://www.heinrichsweikamp.com/?id=479&version=de (German) or http://www.heinrichsweikamp.com/?id=479&version=en (English)
Re: hwOS for OSTC3, cR and OSTC 2: 2.00 released
Posted: 11 Jan 2016, 17:34
by algo
nach dem Update auf v2.00 habe ich jetzt folgendes Problem:
Der rechte Button geht gar nicht mehr, der linke normal. D.h. ist kann zwar das Menü aufrufen und runterscrollen, aber keinen Menüpunkt mehr auswählen.
Dazu kommt, dass der OSTC2 gleich wieder angeht, nachdem er in Standby gegangen ist.
Da der rechte Button nicht geht, komme ich auch nicht mehr dazu, Bluetooth anzuschalten und eine alte Firmware aufzuspielen.
Besteht eine Chance, das irgendwie zu beheben?
Danke & Gruß,
Posted: 11 Jan 2016, 17:52
by algo
kleine Korrektur:
er geht doch in Standby (er geht vom Menü erstmal zurück zur Hauptansicht; das hatte ich irgendwie nicht mehr auf dem Schirm).
Rechter Button geht trotzdem überhaupt nicht mehr (kaltes Wasser, stark drücken, klopfen, etc)...
Posted: 11 Jan 2016, 18:33
Hallo Alex,
Das hat sicher nichts mit der 2.00 zu tun (Die Knöpfe benutzen eine eigene Software, die mit diesem Update nicht angerührt wurde) und (hoffentlich wenig überraschend) wir haben die 2.00 mit allen betroffenen Geräten getestet bevor ich sie hochgeladen habe.
Zu Deinem Problem: Kühle den Computer mal etwas ab (Kühlschrank), dann sind auch Taster mit hoch eingestellten Empfindlichkeitswerten benutzbar. Dann ins Menü -> Konfiguration -> Mehr -> Mehr und stelle den Wert für den betroffenen Taster auf 30% oder weniger. Dann noch das Menü bestätigen und es sollte auch bei Dir wieder leicht laufen.
Klopfen bringt übrigens nichts, der Taster muss mittig, kurz und schnell gedrückt werden.
Posted: 11 Jan 2016, 18:53
by algo
danke für die schnelle Rückmeldung, werde ich mal probieren.
Allerdings gingen beide Taster direkt vor dem Update, sonst hätte ich das Bluetooth ja gar nicht aktivieren können...
Gruß, Alex
Posted: 11 Jan 2016, 19:30
by algo
also, ich habe den OSTC2 im Kühlschrank runtergekühlt. Dann ging der rechte Taste extrem schwer. Ich bin ins Menü rein, die Einstellung war 60% für links und 20% für den rechten Taster.
Nachdem ich aus dem Menü wieder raus bin (habe die Einstellungen für den rechten Taster "einmal im Kreis" wieder auf 20% gestellt), geht der rechte Taster wieder besser... ich werde den OSTC jetzt mal erwärmen und Morgen schauen, was er macht...
Schönen Abend noch.
Gruß, Alex
Posted: 11 Jan 2016, 22:20
by sharpw
Where do you configure the safety stop? Connecting the OSTC3+ to Subsurface 4.5.3 on Win8.1 does not bring up the option.
Posted: 12 Jan 2016, 12:11
There is no software supporting this currently. I quite sure it will be available in e.g. "subsurface" or "Diving Log" soon.
Posted: 12 Jan 2016, 18:53
by sharpw
Matthias,
Thank you. Looking forward to a Subsurface update in the near future, hopefully.
Posted: 17 Jan 2016, 21:33
by DennisA
1) I had trouble with updating. I got readByte timeout. It happened at different places in the process. In the fifth try I succeeded.
2) Thanks for the lost gas functionality. However, I have tested it in the simulator, and it doesent seem to affect the decoplan if I turn a decogas on/off. Is that perhaps a bug in the simulator part?
Posted: 18 Jan 2016, 12:37
> part?
It should work in the simulator, too. You need
a) a deco gas with change depth configured
b) some deco
c) to deactivate the gas below the planned change
-> The decoplan recalculates (Which may take a while).
Re: hwOS for OSTC3, cR and OSTC 2: 2.01 released
Posted: 02 Feb 2016, 11:26
updated for 2.01 release
Posted: 27 Feb 2016, 18:19
by Cristian
Hi Matthias
Is there an option to display the PPO2 for the diluent, in relation with the depth on the screen?
Cristian
Posted: 04 Mar 2016, 12:15
Cristian Wrote:
> Hi Matthias
No.
Posted: 08 Mar 2016, 12:54
Continue here: read.php?6,16368
