hwOS for OSTC3, cR and OSTC 2: 2.03 released
Posted: 11 Mar 2016, 10:16
The new OSTC3, cR and OSTC 2 firmware 2.03 is now available for download: http://www.heinrichsweikamp.com/?id=479&version=de (German) or http://www.heinrichsweikamp.com/?id=479&version=en (English)
This update is strongly recommended for OSTC3 users. It's optional for OSTC2 and cR users.
The firmware itself can be set to English, Deutsch, Italiano and Français.
New since 1.90 (Blue for changes since 2.01):
BUGFIX: Fix missing ccr setup menu (From 2.02)
BUGFIX: Fix rare issue after battery change (OSTC3 did not start properly)
BUGFIX: Divetime >99mins was not displayed (Only OSTC2 with serial > 10500)
BUGFIX: Minor layout fixes in divemode (Dynamic gaslist and stopwatch)
BUGFIX: Minor language updates
NEW: Logbook marker can be set in dive mode menu (OC only)
NEW: Logbook shows markers with small orange boxes in the profile
NEW: "Lost Gas" feature allows disabling gases during the dive
CHANGE: Show velocity from 5m/min or more (Ascend or descent)
BUGFIX: Make sure SP1 is always selected on start in Auto-SP mode
CHANGE: New segmented speed graph in divemode
NEW: Safety Stop can be configured (Start-, End- and reset-depth + length of stop) via PC
BUGFIX: minor text allignment in CCR mode
CHANGE: fix timing issues during Bluetooth download (Bluetooth models only)
CHANGE: Logbook now shows end-of-dive date and time for dives made with firmware =1.92
BUGFIX: Text alignment in logbook
NEW: Show actual dive count in logbook list view (If <1000)
BUGFIX: Minor language and text aligment fixes
BUGFIX: German texts in ppo2 menu were too long for screen resulting in resulting in text display issues
CHANGE: Do not show ppO2 in warning area if already shown in custom view
BUGFIX: Logbook list view for more then 100 stored dives
CHANGE: minor language updates
Details on hwOS: http://www.heinrichsweikamp.com/?id=335
Btw., Subsurface will automatically prompt for an update making the process very comfortable and available for many platforms (like old 32bit Systems).
We also did major updates to the manuals! They are available here: http://www.heinrichsweikamp.com/?id=479&version=de (German) or http://www.heinrichsweikamp.com/?id=479&version=en (English)
Re: hwOS for OSTC3, cR and OSTC 2: 2.03 released
Posted: 13 Mar 2016, 11:39
by netway
Wie kann ich die Parameter für denn Sicherheitsstopp änder?
[quote="NEW: Safety Stop can be configured (Start-, End- and reset-depth + length of stop) via PC"]
Oder muss ich da noch auf ein Update von Subsurface (benutze V4.5.3. für den Mac) warten?
Vielen Dank für deine Antwort und ein schönes Wochenende noch.
Gruß Christopher
Posted: 14 Mar 2016, 13:31
Das Feature wird aktuell noch von keiner PC-Software unterstützt. Aber immerhin kann der OSTC es schon.
Posted: 15 Mar 2016, 23:34
by glance
You can use http://subsurface-divelog.org/downloads ... 026fdd.dmg , which is a pre-release of what is to become 4.5.4, and it contains the Safety stop configuration parameters.
For anyone who would like to try it on windows, the url is:
http://subsurface-divelog.org/downloads ... 026fdd.exe
Try it out, and please report back how it works.
//Anton
Posted: 16 Mar 2016, 10:36
Hi Anton,
Thanks for the ongoing support for the OSTC's in Subsurface (tu)
Posted: 17 Mar 2016, 11:21
by steficic
safety stop configuration parameters are not working with beta subsurface 4.5.3-31 and FW 2.03 on OSTC 2.
I tried to set up the safety stop start at 6m, but it starts anyway at 5m and it stops going to 5,1m as usual. Setting new parameters, saving and reading them with subsurface doesn't work :-(
Boris
Posted: 18 Mar 2016, 13:28
by glance
If you're having problems with the configure dive computer functionality in subsurface, id suggest that you create a libdivecomputer log file from that page, and post it here. That way i can take a look at whats happening.
//Anton
Posted: 18 Mar 2016, 14:34
by glance
Did some reading of the code and spotted the bug.
The internal values ain't in meters, they are in 0.1 meters. Bugfix coming in the next beta, and i'll be posting links when they are built.
//Anton
Posted: 18 Mar 2016, 20:20
by glance
You can now test a patched version from http://subsurface-divelog.org/downloads ... 66a8de.dmg
Posted: 19 Mar 2016, 23:01
by chrismoore02
Hi Glance
This version still does not change the setting in the OSTC2 my safety stop only starts at 5m no matter what you set it too.
Chris
Posted: 20 Mar 2016, 21:51
by glance
Can you create a libdivecomputer log file as described previously, for me to look at.
//Anton
Posted: 22 Mar 2016, 11:30
Hi Anton,
Attached is logfile (Made with 4.5.4-3-gea281b66a8de and hwOS v2.03). Looks ok for me and works as designed. Stop starts at 6.0m after configuring.
EDIT: Starts from 6,09m to be precise.
Posted: 24 Mar 2016, 20:10
by steficic
Safety stop works with hwOS v2.03 and latest Beta 4.5.4 :)
I can have finaly the safety stop at 6-3 meters, when diving with my recreational divers.
Of course, not need it for technical dives.
Boris
Posted: 24 Mar 2016, 20:17
by steficic
is it possible to display decimal values for the temperature in surface mode?
With Subsurface is possible to correct the temperature off-set now, but it can't be set correctly without the decimal values displayed in surface mode.
Boris
Posted: 24 Mar 2016, 21:11
by chrismoore02
Right it does work when set to 6.1m not 6m my mistake sorry guys.
Thank you for the continued support and development :)
Posted: 18 Apr 2016, 16:59
Continue here: read.php?6,16526
