Hardware, Open Source, Logging Frequency and Resolution
Posted: 12 Jun 2016, 12:02
Hi
I'm considering buying an OSTC Sport. I like open source software and I mostly use Linux; being able to read logs on my Linux machines is important to me. I like to know how things work and it is nice to be able to modify them if necessary.
I've been trying to find the following information, but as yet haven't been able to locate it :
What hardware is present inside the OSTC Sport ? The MCU is a PIC18F87K22, but what about the compass, temperature sensor, pressure sensor and Flash ?
What size is the flash storage and how much of it is used for logging ?
It appears that the Sport is update-able with firmware produced from the open-source code on Bitbucket, but some users online say that this isn't the case. I just want to confirm that the Sport runs open-source code and can be updated with user-developed firmware, specifically firmware compiled from code on the bitbucket.org/heinrichsweikamp/hwos_code repository ?
Apologies for my n00b questions, I just want to make sure I'm buying the right thing.
Thank you
Thank you
