Hi everyone, I am looking for help regarding a strange behaviour of the battery indicator of my OSTC MK2. I´m running fw 3.13.
I am going on a holiday trip next week and thought I´d charge my OSTC before. So I charged it for 17hs first. The battery indicator changed to red while charging and stayed half full. After charging it turned to green, still half full.
I thought, maybe 17hs are not enough for the unit to log a full load cycle. I connected it again, this thime for 48hs ( I forgot it, to be honest ). Result : the same as before.
Now my questions :
Does the half full indicator mean, that the battery is only charged half ? Will it possibly die during my trip ?
Could it be that the current of my charger is to weak to charge the battery ? I`m using a plug to usb adapter, don´t know how much current it delivers.
Any other ideas ? Any setting that I could change ?
save diving !
Jochen
Battery indicator stays at half full
Re: Battery indicator stays at half full
Check CF74. "CF" means "Custom Function" and can be found in Menu -> Setup -> Custom Functions III. Make sure it's set to "1800", which is 30 hours.
Michael
Sydney
Australia
OSTC 2 11528
Sydney
Australia
OSTC 2 11528
Hi Michael, thanks for your reply. I checked CF74 and it´s set to 1800 ( I didn´t play around with it ).
It's intent behaviour. Battery will jump to FULL again if the unit is fully charged and the cable is removed.
While charge is added only a full charge will reset this timer.
I have the same problem with an OSTC 2C. But even with a full charge no modification of battery level. Even with a full charge of 48H, with CF74 at 1800.
Could you help me ?
Stephane
Could you help me ?
Stephane
Try a "reboot" from the reset menu.
In my case that solved the problem immediately. Thanks Matthias !
Thanks for the feedback.
