Diving Log downloader update
divinglog
Es gibt ein Update für den OSTC Downloader für Diving Log 4.0: ImportOSTC.zip
[Version 1.4.0.0 - 23.07.2009]
- Neue Funktion zum Import in vorhandene Tauchgänge (Mehr Infos)
- Support der Firmware 1.40 Funktionen
- Unterstützung der Custom Functions bis CF41
Die Zipdatei nach dem Download in den Diving Log Programmordner entpacken.
New version of the OSTC downloader for Diving Log 4.0: ImportOSTC.zip
[Version 1.4.0.0 - 2009/07/23]
- New option to import into existing dives (read more)
- Support of firmware 1.40 features
- Support of Custom Functions up to CF41
Extract the zip file into your Diving Log program folder and replace the old files.
Steve
Re: Diving Log downloader update
thanks a lot
works nice
works nice
Steve
CMAS 2* Instructor
Belgium
CMAS 2* Instructor
Belgium
BerndAllgäu
Hi @ all,
am i right that in the diving log the starttime of dives in reality is the endtime?
regards Bernd
regards Bernd
divinglog
Hallo Bernd
Nein, die Startzeit (Uhrzeit) ist normalerweise die Einstiegszeit ins Wasser. Die sollte auch korrekt vom OSTC übernommen werden.
Schöne Grüße,
Sven
Schöne Grüße,
Sven
Bradipo
Sven,
The time recorded by the OSTC is definitely the end time of the dive, not the start time. I don't know exactly why this choice was made, but it is not a major issue.
Ciao,
Giovanni
Ciao,
Giovanni
True, the OSTC saves end-of-dive time. To be honest, I don't know why we choose this...
divinglog
Hello
Ups, I've never recognized this. But at least it's not a bug in my parser code
If you want I can add an option to my downloader so that the entry time is automatically calculated and stored in the logbook instead of the exit time. It would be optional, so everyone who prefers the current way would not be affected.
Kind regards,
Sven
Kind regards,
Sven
Bradipo
Sven,
that would be great.
Not that it would change my life, but every time I open the logbook I think that the clock on the computer needs to be adjusted, then I realise it is the end time of the dive
Thanks!
Giovanni
Thanks!
Giovanni
divinglog
Hi Giovanni
I've added an option "UseExitTime" in the "Advanced Settings" to control this. By default it will automatically calculate the Entrytime and store it in the logbook. If someone wants the previous behaviour you must change this setting to "True" and then the time will match with the internal OSTC logbook time.
Click here to download the update: ImportOSTC.zip
Thank you!
Sven
Thank you!
Sven
Bradipo
Hello Sven,
Thank you very much!
Ciao,
Giovanni
Ciao,
Giovanni
Hiasl
Hi Sven!
Wo finde ich das? Ich such mir grad den Wolf.....
Hi Sven!
OSTC Mk II #661
OSTC Mk II #661
divinglog
Hallo Matthias
In der deutschen Version ist das der "Einstellungen" Button direkt im ersten Schritt des Download Assistenten. Dort gibt es jetzt die Option "UseExitTime". Die musst du aber nur ändern wenn du die Ausstiegszeit im Logbuch ablegen möchtest. Standardmäßig wird jetzt die Einstiegszeit abgelegt.
Schöne Grüße,
Sven
Schöne Grüße,
Sven
Hiasl
