oddity with 'calculate deco'
Posted: 17 Dec 2016, 11:04
by ebertalex
Hi there,
just so you know there is an oddity with the 'calculate deco' feature.
I am using the OSTC4 firmware version 1.1.8.
When I try to calculate a dive of 20 min to 50m on air with NX50 an O2, the NX50 does not show up in the deco plan. Yet, when I move to gas consumption, the required NX50 Volume shows.
Calculating 60m with otherwise the same parameters does not have the issue at all, both deco gases are shown.
Re: oddity with 'calculate deco'
Posted: 19 Dec 2016, 11:43
Hi Alex,
Which change depth is configured for the two deco gases? They are set as Type: Deco?
Posted: 11 Jan 2017, 10:58
by ebertalex
I have configured Nx50 and O2, both as deco gases.
Change depth for Nx50 is set to 22m. Change depth for O2 is 6m.
Also, I use GF30/80 (as soon as I set GF30/75, the problem does not show up).
It is as if Nx50 "is there" in the background but it kind of "slips" from the screen.
Please see attached pictures. First row: configuration. Second row: Simulation results.
Posted: 11 Jan 2017, 16:01
Hi Alex.
Gas changes are not displayed seperately. The gas changes occurs at 22m that is prior to the first stop at 18 m which is the first entry in the list. It is shown if you have depper stops (like max. depth is 60m instead of 50m: first stop at 27m).
kind regards,
Christian
Posted: 12 Jan 2017, 11:13
by ebertalex
Understood. Thank you Christian!
