				Charging issue - blinking red light
				Posted: 26 Mar 2017, 14:32
				by gorcio
somehow, I have never been able to charge mu unit fully, in one go.  Usually it starts charging fine, then at random inteval, it starts blinking red light.  It requires disconnecting the charger, reconnecting it and then continuing charging.
While I can charge my unit, it requires monitoring and that's a bit annoying.  Would you happen to have any idea what might be going on ?  It is not a position of the charger, because this is actually fixed.
Best regards,
gorcio
				Re: Charging issue - blinking red light
				Posted: 26 Mar 2017, 18:57
				Hi Gorcio,
That's the overtemperature warning of the charger. No need for you to do anything, charging will resume automatically. We have set the overtemp-warning to 45°C, which is very conservative, to protect the battery in the OSTC4.
				Posted: 01 Apr 2017, 19:35
				by sadsani@gmail.com
				as much as I love this computer ... I think its the best computer I have owned and believe me in 16 years I have owned a lot ... charging it is like 1 out of 100 score
charging this is giving me a nightmare
				Posted: 03 Apr 2017, 12:45
We've changed the Qi charging standard to 1.2 which is way less critical in positioning of the charger. What's your serial number? If it's one of the first units (like first 150 or so) we can modifify the charging circuity here free of charge.
				Posted: 07 Apr 2017, 19:52
				how can we do that? Will the fix be to the computer itself?
				Posted: 08 Apr 2017, 08:23
				by gorcio
				How long would such change take ?  I am tempted to send my unit ...
gorcio
				Posted: 10 Apr 2017, 12:17
				Hi Gorcio,
We can do the modification within one day - but the computer needs to be at our place for this. Please contact us directly:
info@heinrichsweikamp.com
				Posted: 14 Apr 2017, 19:18
				by gorcio
				Ok - will get in touch with you ... probably just before going on a longer work trip or when I know for sure I won't need the unit.  But I will certainly contact you - thank you for your flexibility and your readiness to support your customers
.  As always - your support should be an example to other producers.
gorcio
