HUD
Posted: 07 Aug 2009, 00:44
by kimanton
Hi!
What kind of HUD`s you`re using with the OSTC?
Where did you get those?
Thanks for looking.
Best, Kim
Re: HUD
Posted: 08 Aug 2009, 18:30
by kimanton
No one uses HUD?
How about the LED-assembly on rEvodream, could it be used by connecting the red and green LED to the O2-module ja drive it with DS1-protocol?
Re: HUD
Posted: 08 Aug 2009, 20:48
by sailor
You can use any kind of LED-setup as HUD.
Home-made, third party, whatever.
The O2-board can be directly connected to 3 LEDs.
But only highly efficient LEDs will work without a seperate power-supply to the board.
The board can even be used stand-alone to drive LEDs without the OSTC.
I don`t know if anybody already uses HUD with the OSTC.
My setup is not finish yet but i'm only planning to use the board as a PO2 interface to the OSTC but not to drive a HUD.
Re: HUD
Posted: 10 Aug 2009, 12:08
by kimanton
Thanks Sailor
Not too much info to be found on this matter..
Re: HUD
Posted: 20 Aug 2009, 12:02
As far as I remember there is one OSTC user on the rebreatherforum www.rebreatherworld.com with a HUD attached to the Monitor electronics.
Re: HUD
Posted: 27 Aug 2009, 14:25
by onliner
As from now i have the HUD with the o2 board in use. It works fine and with the big ppO2 display, i don't miss a thing. pictures are following... ;-)
Volker
Re: HUD
Posted: 30 Aug 2009, 18:43
by onliner
Hai folks,
Everyone, who want to see some pictures, find some here http://213.157.31.210:92/index.php?article_id=91
Volker
