Mod for first gas is wrong
KEngelstoft
Hi, when editing a first/travel gas on OSTC3 the MOD is calculated based on ppO2 1.6 instead of 1.4 bar. This should only happen for deco gasses.
Best Regards,
Kasper
OSTC3 #576, replaced by OSTC3 #2827
Kasper
Re: Mod for first gas is wrong
The hwOS currently uses only one max. ppO2 setting for all gases. And the default for this is 1.60bar.
Hi all,
meanwhile, there are two settings, a ppO2 bottom max and a deco max, which are used dependent on the gases configured as deco gas or something else (first, travel).
