Issue to export from Subsurface w/ OSTC Sport V10.35
Posted: 06 Aug 2017, 12:41
by Motardplongeur
Hello
Since V10.35* on my Sport, I can't export dives from Subsurface to CSV files ; Subsurface answer 'failed to read XML memory' (red band on the bottom of the screen) and no file is created.
If I try to export to a XML file, it create the file but empty, just a warning:
"Erreur d’analyse XML : mal formé
Emplacement : file:///C:/Users/chris/Desktop/toto.xml
Numéro de ligne 23, Colonne 59 :
No issue to export from Sport to Subsurface & no issue with dives exported by V10.34 or older versions.
I put a message on Subsurface forum but no answer (https://subsurface-divelog.org/user-forum/, win section, same author).
I use Win10, all softwares are updated.
*Dives with issue have been performed with V10.35 and exported to Subsurface with V10.35 and 37, same problem.
Can you help me ?
Thanks.
Re: Issue to export from Subsurface w/ OSTC Sport V10.35
Posted: 06 Aug 2017, 21:55
by glance
Your xml file looks damaged, due to a bug in subsurface, thats fixed in the current development tree.
Open toto.xml and cleanup that Deco model info row or just delete it and things will work again.
//Anton
Posted: 07 Aug 2017, 19:07
by Motardplongeur
It works (to have readable XML file, not for CSV)
Hoping this issue will be solved in the next Subsurface update.
