NEW OSTCTools for Android - Release
Posted: 25 Jan 2018, 07:52
there is a new App with the OSTCTools.
HWOSConfig for Android.
What is implemented:
-Personalizing (setting of Customtext)
-Firmware update for HWOS OSTCs, Tech and Sport.
Supported OSTCs:
-OSTC 2 (new)
-OSTC Sport
-OSTC 3 (April 2015 and later)
-OSTC plus
I will add more features to the App step by step.
But due to the Bluetooth problems that some users have, i decided to release this Alpha version. With my testdevices firmware upgrade works like a charm.
Permissions:
the App needs
-Read/write access on the device
-Bluetooth access
-access to the internet.
There are no ads, and no data where collected.
Step by step instructions:
Install the App from Google
https://play.google.com/apps/testing/eu ... hwosconfig
-Accept permissions (only once after installation
Select your OSTCType (HWOS Tech or HWOS Sport) and click on download to get the latest firmware.
When you wipe to the right, you can see the history of changes file, provided with the firmware.
-Switch Bluetooth on your OSTC on.
-Go to Android settings, search and connect your OSTC.
-In the App select your OSTC from the combobox (make shure Bluetooth is on)
-click "CONNECT"
The type of the OSTC will be automatically detected and set in the combobox.
-check the type of the OSTC in the combobox, if neccessary change it.
(my OSTC Plus with Tech firmware tells me that it is a sport version, but it isn't, i have to clarify this with matthias)
After connection there is a line shown below the Download Button that tells the Identity of the OSTC (type). Plus users can mail me, or post the line here, together with te type of ostc (tech or sport).
-make shure you have a firmware version selected.
-click on "UPLOAD"
-be patient
Custom Text:
-Select your OSTC in the App
-Click on "CONNECT"
-Click on "CUSTOM TEXT"
-Set the text
-Click "OK"
-Click "DISCONNECT"
Have fun
Please give feedback per mail or here in the thread.
* Now in German
es gibt eine neue App bei den OSTCTools.
HWOSConfig für Android.
Was ist implementiert:
-Personalisierung (setzen von Customtext)
-Firmware update für HWOS OSTCs, Tech und Sport.
Unterstützte OSTCs:
-OSTC 2 (neu)
-OSTC Sport
-OSTC 3 (April 2015 und später)
-OSTC plus
Ich werde die App weiter ausbauen und weitere features implementieren,
aber wegen der vielen Probleme die manche mit Bluetooth mit Win oder Mac haben, habe ich entschieden diese Alpha Version freizugeben.
Mit meinen Test OSTC's funktioniert der Firmware update absolut problemlos.
Rechte:
die App benötigt
-Lese/Schreib Zugriff auf dem Smartphone (zum ablegen der Firmware)
-Bluetooth Zugriff (Verbindung mit OSTC)
-zugriff zum Internet. (Download der Firmware)
Keine Werbung und es werden auch keine Daten erfasst.
Schritt für Schritt Anleitung:
Installation der App von Google
-Permissions erlauben (nur einmal nach ersem Start)
-Einstellen des OSTC Typs (HWOS Tech or HWOS Sport) und klick auf "DOWNLOAD" um die aktuelle Firmware zu laden. it einem Wisch nach rechts wird die History, die mit der Firmware kommt angezeigt.
-Auf dem OSTC Bluetooth einschalten
-In den Android Bluetooth Einstellugnen, nach dem OSTC suchen und verbinden.
(muss nur einmal gemacht werden)
-In HWOSConfig den OSTC in der Auswahlbox (Bluetooth) auswählen.
-Vergewissern das Bluetooth am OSTC noch an ist.
-Klick "CONNECT"
Der OSTC Typ wird automatisch ermittelt und die Auswahlbox "OSTC Typ" entsprechend eingestellt.
-überprüfe den Typ in der Auswahlbox, falls nötig ändern.
(mein OSTC Plus mit Tech firmware ist der Meinung das es ein Sport ist, ist er aber nicht, ich muss das mit Mathias klären)
Wenn der OSTC verbunden ist, sthet unter dem Download Button eine Zeile mit der OSTC Identity (der Typ). OSTC Plus Besitzer können mir diese Zeile bitte zusenden oder hier posten. Bitte auch posten wenn andere OSTC falsch erkannt werden. Zusammen mit dem richtigen Typ.
-überprüfe ob eine Firmware ausgewählt ist
-klicke "UPLOAD"
-abwarten und Tee trinken
Personalisieren/Custom Text:
-Bluetooth am OSTC einschalten.
-OSTC in the App auswählen
-Klick auf CONNECT
-Klick auf "CUSTOM TEXT"
-Text einstellen
-Klick "OK"
-Klick "DISCONNECT"
Viel Spass.
Bitte um Rückmeldungen per Mail oder hier im Thread.
Regards/Grüße
Supported OSTCs:
-OSTC 2 (new)
-OSTC Sport
-OSTC plus
Permissions:
the App needs
-Bluetooth access
-click "CONNECT"
-click on "UPLOAD"
-be patient
Custom Text:
-Click on "CONNECT"
-Set the text
-Click "OK"
-Click "DISCONNECT"
Have fun
* Now in German
Unterstützte OSTCs:
-OSTC 2 (neu)
-OSTC Sport
-OSTC plus
Rechte:
die App benötigt
-Klick "CONNECT"
-klicke "UPLOAD"
-Klick auf CONNECT
-Text einstellen
-Klick "OK"
-Klick "DISCONNECT"
Viel Spass.
Regards/Grüße
