Updating CF74
Posted: 17 Apr 2018, 09:49
by Clownfish
My OSTC 2N has a dead left button so can no longer fully utilise it. I now use as a back up to my OSTC 2. All has been well time I recently corrected the time on it using Subsurface (end of daylight saving). Since then, the battery counter no longer works showing 0% despite fully charging (it is charged as colour changes to green). Despite attempting to change CF74 to 1800, it will not upload this data. This also happens when I use OSTC Config.
Any ideas on how to change it as having the battery warning on all dive is not great.
Re: Updating CF74
Posted: 29 Apr 2018, 12:31
by Clownfish
Anyone??
Re: Updating CF74
Posted: 30 Apr 2018, 17:59
by scubatinoo
Matthias suggested a reboot in this thread:
http://forum.heinrichsweikamp.com/read. ... 7201,17837
But i don't know if this will help you as long as you have a non working button...
Re: Updating CF74
Posted: 07 May 2018, 14:43
You could also do a magnet reboot (No button needed):
- Attach to USB
- toggle the reboot with a magnet near the center screw in the back
That will reset your ON-Time counter and the battery warning should disappear.
Re: Updating CF74
Posted: 07 May 2018, 15:59
To add: I can also make you a special firmware resetting the CF74 to it's default after installation.
Re: Updating CF74
Posted: 06 Jun 2018, 05:10
by Clownfish
> needed):
> - Attach to USB
> screw in the back
> regards,
Just tried this, does seem to reboot but no change to the battery symbol, always flashing. Any chance of the special firmware?
Re: Updating CF74
Posted: 27 Jun 2018, 11:52
by Clownfish
Tried magnet reboot again without success.
Re: Updating CF74
Posted: 27 Jun 2018, 11:57
You can try this attached firmware, which will reset CF74.
Re: Updating CF74
Posted: 28 Jun 2018, 10:35
by Clownfish
Thanks, appears to have reset it successfully.
Re: Updating CF74
Posted: 30 Jun 2018, 12:38
by Clownfish
Thanks Matthias, now working perfectly (well, not the left button).
