Deco softwares comparison
Posted: 17 Aug 2018, 16:20
Hi
I know some of you are skilled progammers for deco softwares...
I am a trimix diver, rather new to the sport (but unless you have done it for 20+ years I guess you still are:) and I am wondering about the multiple dive plan softwares available:
I have run 10 dive plans for different scenarios (varying the depth, BT, configuration of deco gases, with/without helium) on several deco softwares/firmwares (ostc2, multideco, Ideco, ostc-planner, garmin mk2...) BUT all based on Buhlmann ZH L16C with the exact same parameters (GF, etc...).
For the same dive plan, differences of the overall deco time from one software to another are up 10 to 20%. And there is no apparent consistency/correlation between them, like we can't say for ex that one is just always a bit more pessimistic or optimistic etc... I know some programs account for the descent time as BT or not, but I doubt it could explain the differences.
It can entail +/-10 minutes on a 50minutes total deco time depending on which program you follow to plan your dive. Since we are taught to follow the plan by the minute, +/-10 minutes is a lot!
Does it mean we should all opt for "deco on the fly" estimates and use no computer...
I (naively) thought that because the algorithm (Buhlmann ZH L16C) and the parameters were the same for each device/software I ran, the programmed code would be the same or very close, thus yielding very little difference. But it does not seem to be the case ?
Tks
Jean-Luc
Tks
Jean-Luc
