OSTC cR + hw HUD S8
Posted: 20 Aug 2018, 12:10
Please could you inform us little bit more about this package and how we can connect OSTC cR + hw HUS S8 together on 3 oxygen sensor?
We need this kind of design, computer + HUD to control mCCR.
Do you have a wiring diagram? It will be very helpful.
user manual
"1. S8 connector
With the S8 connector you can connect di-
rectly up to three oxygen sensors to your
OSTC cR. Optionally you can use a digital
connection via the hw HUD S8.
The S8 connector is triple O-ring sealed.
This construction is very robust. The OSTC
cR can be connected to standard oxygen
sensors with a common ground.
Before attaching the sensors the first time,
pay attention to the correct configuration
of the pins. The S8 connector has the fol-
lowing pin configuration:
• Pin G: ground, sensor 1,2 and 3
• Pin 1: plus, sensor 1
• Pin 2: plus, sensor 2
• Pin 3: plus, sensor 3
The maximum sensor voltage is 165mV per
sensor.
The minimum voltage for calibration is
7 mV in air (21% O2) and 36 mV in pure ox
ygen (100% O2).
The products of heinrichs weikamp use a
100 kOhms load resistor for analog O2 cell
inputs.
The remaining four pins are designated for
the USB connection. Only use the included
original cable! Via USB you can recharge the
OSTC cR and connect it to a PC or notebook
to read logbook data and install updates.
Caution
A dive with an open S8 connector can irre-
parably damage the OSTC cR. If no S8 cable
is connected, always close the socket with
the cap. "
many thanks
Petko
user manual
"1. S8 connector
sensor.
ygen (100% O2).
inputs.
Caution
the cap. "
many thanks
Petko
