minimum gas on the fly
Posted: 08 Oct 2018, 18:53
I started thinking about minimum gas while diving and found a very good function on hwos. Of cource it`s not a replacement for planing, it`s only an addition.
I would like to know the minimum pressure at current deep to get up with a buddy who lot/emptied his gas. (assumption 3x normal SAC(AMV))
Is the following correct?
Only one Gas:
-Set the AMV "bottom gas" to 60 l/min (e.g. 3x normal)
-Set only one Gas as active
-Set Future TTS to "problem solving time" e.g. 3min
-Set Tank size
Now i should see while diving at the custom view "Gas Needs" how much gas i must have to solve the problem in 3min and get up to surface form current depth.
One travel Gas and Deco gas:
(Minimum gas to get safe to the first gas-change-depth)
-Set the AMV "bottom gas" to 60 l/min (3x normal)
-Set the AMV "deco gas" to 20 l/min (normal)
-Set Tank size
Now i should see at the custom view "Gas Needs" how much gas i must have to solve the problem in 3min and get up to the first gas-change.
This methode has the disadvantage that the gas-calculation at the simulator is wrong. Future Deco and "problem solving time" may differ but you have only one parameter.
Did I made some mistake? Only one thing is right: you can`t have enough gas
Only one Gas:
-Set Tank size
-Set Tank size
