TR problem seeing transmitter
Posted: 16 Nov 2018, 01:01
I'm having problems getting my OSTC2 TR to see the transmitter. It will take minutes for the computer to even see the transmitter, and once it does, it will only do so for a short while before the pressure reading is lost again. This behaviour is repeatable, although timing varies, and I've taken a video (see below, I've included rough timestamp data). The timing between events will vary a bit with each attempt. Sometimes the computer goes to sleep without ever seeing the transmitter.
Once it sees the transmitter, I can pair the computer to the transmitter, but no pressure is displayed. Computer runes 2.99beta, but the same thing happens with v10.49 Sport. RX version is 1.32, the latest as per v10.49.
Can anyone tell me what I'm doing wrong here? This is not my first air integrated computer, never had such issues before.
https://youtu.be/-jsssf7_Qxc
00:13 turn on pressure (~180 bar)
00:25 computer turned on and on the surface pressures screen
01:50 transmitter and pressure shows
02:50 pressure gone again.
A second video showing the same, as well as some other odd readings (there are no other transmitters nearby that I know of). I apologise for the video being upside down.
https://youtu.be/HYzgtzHmPNc
00:08 turn on pressure (~180 bar)
03:01 first time a trabsmitter shows in surface pressures screen
03:55 second trandmitter ID 10527 shows up, reading 183 bar??
04:22 trying to pair, shows transmitter IDs 210F and 291F, but not 8463
05:00 all readings gone again
