OSTC 2 TR - Batterie indicator issue
Posted: 31 May 2019, 09:53
by Alexis
Hello
My OSTC 2 TR (#17241 Tech firmware 3.01) was stored (on a safe dry place) fully charged for 5 month.
When restarting it, I had a the Battery level at 0% (voltage 3.4v)
I tried to recharge it but very quickly the charger turned red. I've updated the firmware to the latest version (3.01). No change.
Beside that it seems to work perfectly.
Do you have any Idea of what is going on and how to address it?
Thanks for your help!
Re: OSTC 2 TR - Batterie indicator issue
Posted: 31 May 2019, 10:32
Can the USB power adapter supply at least 1.5A?
Posted: 31 May 2019, 10:48
by Alexis
Yes
I tried severalls (2 iphone USB charger and a powerfull multi USB charger) that I already used in the past to the charge the computer with the same result.
Posted: 31 May 2019, 11:07
by karip
Use PC usb port. I can do only that way.
Posted: 01 Jun 2019, 12:46
by Alexis
Hello
Thanks you! It worked using the PC USB port
Is there a USB charger that would work fine and that you could recommend if you do not want to Travel with a computer.
Posted: 01 Jun 2019, 15:27
by Ralph
Any USB supply that is capable of delivering 2 Ampere will do. Stay away from smartphone and tablet chargers as they often do some none-USB standard things on the supply lines in order to detect their mates (and then may change the voltage, etc.).
Posted: 01 Jun 2019, 18:52
by Alexis
Many thanks for your help !
I really appreciate it!
