Sport not suggesting gas switch - Why?
Scuba_Wandy
Post by Scuba_Wandy »
Hey everyone,
So I've had a Sport for a few months and was diving with it this weekend doing the BSAC ADP course which is why I bought the computer.
When I first got it, I was playing with the simulator feature and noticed that using that, when I got to the depth needed to be able to do the gas switch, the computer would tell me and ask if I wanted to switch the the relevant deco gas and gave me a one button press select option.
This weekend, this didn't happen and it would have quite happily gone to the surface on back gas meaning I had to go into the menu and manually select the deco gas I was using. Not a huge issue, but still more faff than just using the one button select function. Also does this affect the @5 function?
I'm sure I've probably switched a setting that I shouldn't have but I've looked and I can't see what.
Can anyone let me know how to switch the one button function back on again?
Re: Sport not suggesting gas switch - Why?
Gastype = Deco and Change depth configured for the deco gas?
And: Firmware version?
Scuba_Wandy
Hey,
Yes, change depth set to 21m for a 50% deco gas.
Software version 10.53
And: actually in deco? No deco - no gas switch cue for a deco gas...
If doing extended no-stop, gas-switch dives, set all gases to "first" and "work", then switch cues will be produced.
