[OSTC Plus] Bluetooth Connection Issues Verbindungsprobleme
Posted: 08 Sep 2019, 21:44
Greetings,
I can not download the diving logbook of my OSTC Plus with Subsurface.
So far I tried the following with OSTC Plus hwOS Sport 10.53 & 10.58 in Windows 7 and Ubuntu 16 with the Sitecom CN-516 Bluetooth adapter:
- rebooted PC / OSTC
- reinstalled Subsurface
- reinstalled Bluetooth driver
- used different COM Ports
- reinitialized Bluetooth connection PC OSTC several times
- used different computers
- used all available OSTCs in Subsurface
- searched forum for useful hints or information
- tried to mount OSTC manually in Ubuntu (without success)
- installed OSTC Companion 3.0 (CAN CONNECT (with OSTC Sport))
- installed OSTC Planner 2.70.5 (CAN NOT CONNECT (timeout))
- connected with OSTC Companion and tried to pair with Subsurface afterwards (blocked)
- several combinations of switching on Bluetooth on PC/OSTC, connecting, starting Subsurface and connecting
- searched Windows "device manager" (Gerätemanager) without success
The following logs are from Subsurface:
with OSTC hwOS sport 10.53:
[pre]
Subsurface: v4.9.1, built with libdivecomputer v0.7.0-devel-Subsurface-NG (ffbb47297539b873a1bc49d71ebd739639876b65)
INFO: Open: name=COM40
INFO: Configure: baudrate=115200, databits=8, parity=0, stopbits=0, flowcontrol=0
INFO: Timeout: value=3000
INFO: Sleep: value=300
INFO: Purge: direction=3
INFO: Write: size=1, data=BB
INFO: Read: size=1, data=BB
INFO: Read: size=1, data=4D
INFO: Write: size=1, data=60
INFO: Read: size=1, data=60
INFO: Read: size=5, data=0012000251
INFO: Write: size=1, data=69
INFO: Read: size=1, data=69
INFO: Read: size=64, data=28450A354857204F53544373706F727446616269616E2054616E6E2048545356204769657373656E4765726D616E792020202020303135313234323530323231
Event: model=18 (0x00000012), firmware=2613 (0x00000a35), serial=17704 (0x00004528)
INFO: Write: size=1, data=6D
INFO: Read: size=1, data=6D
INFO: Read: size=657, data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
ERROR: Failed to receive the answer. [in /win/subsurface/libdivecomputer/src/hw_ostc3.c:323 (hw_ostc3_transfer)]
ERROR: Failed to read the header. [in /win/subsurface/libdivecomputer/src/hw_ostc3.c:702 (hw_ostc3_device_foreach)]
INFO: Write: size=1, data=FF
INFO: Read: size=1, data=1C
ERROR: Unexpected echo. [in /win/subsurface/libdivecomputer/src/hw_ostc3.c:305 (hw_ostc3_transfer)]
ERROR: Failed to send the command. [in /win/subsurface/libdivecomputer/src/hw_ostc3.c:568 (hw_ostc3_device_close)]
[/pre]
with OSTC hwOS sport 10.58:
[pre]
INFO: Read: size=5, data=0013000000
INFO: Read: size=64, data=28450A3A4857204F5354430000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
Event: model=19 (0x00000013), firmware=2618 (0x00000a3a), serial=17704 (0x00004528)
INFO: Read: size=328, data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
INFO: Read: size=1, data=E6
[/pre]
In addition I installed the FTDI VCP driver 2.12.0.0 and 2.12.28 to try it "old-school" via USB, but this did not work either (I could not figure out how to set USB as transfer mode).
I hope you can help me in this matter,
Fabian
/// Edit 22.12.2019:
I now got Windows 10 installed and it runs with the up-to-date version of Subsurface. I do not know why, but finally I can copy them to my harddrive.
Merry Christmas
[pre]
[/pre]
[pre]
[/pre]
Fabian
Merry Christmas
