Ostc2 V3.05
Posted: 11 Oct 2019, 22:17
by Erik69
Hello
Something strange happened on the lat version v3.05.
I have no deco
The saturation stays 0%
And when I run a deco calculation
54m 40minutes the tts stays at 0
The other point is thatmy dive is in the logbook, but I don't see it with subsurface...
Any helo?
Eric
Re: Ostc2 V3.05
Posted: 14 Oct 2019, 11:05
Apnoa/Gauge mode active?
Re: Ostc2 V3.05
Posted: 14 Oct 2019, 14:35
by Ralph
when the deco calculator doesn't calculate a deco schedule although by depth & time there should be deco, you can probably fix this by doing a "Reset Deco" from the reset menu. This is certainly only a work-around, investigation of the real root cause is still ongoing...
Re: Ostc2 V3.05
Posted: 15 Oct 2019, 12:58
by Erik69
Hi
After disussion with Ralph,it has been solved with a reset deco
Eric
