A few questions about the OSTC plus
Posted: 18 Oct 2019, 19:49
I recently bought an OSTC plus with hwOS sport and had the occasion to use it during a few test dives. So far I'm pretty happy with it.
I have however a few questions.
1. I've been using OSTConf on iOS to help me configure the OSTC and flash the most up to date firmware. I'm surprised because OSTConf reports the OS type as "hwOS Tech" even though the OSTC is running the Sport version. Is this a bug in OSTConf ? (or is it possible that I've been sold an OSTC plus "Tech" with a downgraded firmware ?)
2. What is the latest stable firmware revision of hwOS Sport ? 10.61 appears to be the latest at time of writing and is the one I've flashed, but there's no official communication about it on this forum and this version does not appear in the changelog on the firmware download page.
3. Where can I find the hwOS Sport source code ? I've found the git repository called hwos_code on bitbucket but I only find mentions of hwOS Tech firmware version numbers in the history. Are "tech" and "sport" sharing the same code, if so, why are they not sharing the same version numbers ?
4. I've installed a SAFT LS14500 battery in my OSTC. The manual indicates that the T1 option should be chosen in the "New battery" menu. However only T0, T2 and T4 actually appear in the menu. Both T0 and T2 actually work with this battery, but choosing T0 makes the OSTC wrongfully report a 100% battery level, and choosing T2 leaves the charging function on the OSTC enabled which does sound pretty dangerous.
5. I'm confused by the description of the ppO2 max and ppO2 deco settings in the manual. Is pp02 max used for computing MOD ? What's ppO2 deco used for ? Which one of these two is used for displaying a warning when the ppO2 is too high ? Thanks for clarifying this.
6. Another post from this forum discourages using batteries other that Sanyo UR14500P or Panasonic ICR14500 which both have a 800mAh capacity. But unfortunately they appear to be really hard to come by. I was able to find cheap ICR14500 batteries from china that claim to have a capacity of 2800mAh, and are equiped with a discharge protection circuit. Is this safe ?
Maybe I should mention that I'm using the french version of the firmware.
Thanks for helping.
Thanks for helping.
