hw OS Tech 3.07 - loss of dives saved in the logbook
Posted: 02 Nov 2019, 20:16
by mobu
I have just update from 3.05 to 3.07
It has been updated correctly but when I go into the loogbook, in the main menu, I notice that nothing appears.
How can I recover the dives I had stored in the loogbook in version 3.05?
Thanks.
Re: hw OS Tech 3.07 - loss of dives saved in the logbook
Posted: 02 Nov 2019, 20:22
by mobu
I also notice that Last dive, Divetime, Max. Depth and Average in surface mode is now reset to 0.(My last dive was yesterday). However, my Desat is now 06:00
How can it be possible?
Thanks.
Posted: 03 Nov 2019, 11:14
> 06:00
These values reset with an update or reboot since they are not reload from the logbook. They will be correct again after the next dive. Desat time is reloaded from unvolatile memory and the last stored value was 06:00.
The logbook is untouched with the update and should only reset when you choose "reset logbook" from the reset menu.
Posted: 03 Nov 2019, 14:54
by mobu
[quote="The logbook is untouched with the update and should only reset when you choose \"reset logbook\" from the reset menu"]
I did not choose "reset logbook".
I had to upload twice cos the first time it stopped at 66% of the process and error mensaje appeared. Maybe this affects the loogbook. I do not know.
Any case, can I get them back?
If not, how to configure the numbering of the logbook so that it does not replace the ones I have in the subsurface?
Thanks.
Posted: 04 Nov 2019, 13:35
by tschu
Via Settings > Display Settings > Logbook Offset you can put in your own number of dives. (RTFM
The # in Subsurface are not linked to the # in your dive computer (I've used three different computers in the last years)
/Thomas
