hwOS Sport: New Firmware 10.64
Posted: 21 Feb 2020, 10:23
The new hwOS sport firmware 10.64 is now available for download:
This update is (still) strongly recommended for all users of the 10.56 or later:
BUGFIX: Hardware versions 13-xx-xx and 58-xx-xx could hang up with versions of 10.56 or later
[10.64]
BUGFIX: "Sticky" button behaviour on some hardware versions (Only OSTC 2 (2017), TR and OSTC plus)
[10.63]
BUGFIX: Add surface part at end of dive to surface interval properly
BUGFIX: Average depth in logbook did not took salinity setting into account
CHANGE: Change color of temperature values in logbook to yellow
[10.60]
BUGFIX: Surfacemode could freeze in some hardware versions
BUGFIX: Potential issue with Bluetooth in older OSTC sport models
CHANGE: Default language in EN/DE version is English again
[10.58]
BUGFIX: Version number was not shown in main screen
BUGFIX: Button function could be toggled on charger
10.57:
BUGFIX: NDL in big font display
BUGFIX: Bluetooth mode in old OSTC sport (Red buttons)
10.56:
NEW: Five gases instead of three
NEW: Optional, 2nd Tissue graphic with markers for GF_low, GF_high and M-Value
NEW: Complete new Deco Planner and OSTC Simulator
NEW: 2nd Deco plan can calculate "Gas needs" (Optional) for all gases in real-time
NEW: Optional "Gas change time" and selectable extended stops (Shifting the gas change to the first real deco stop)
NEW: Configurable ascend speed
NEW: Support for more hardware versions (OSTC sport and 2 TR)
NEW: 2nd Layout (With larger fonts and slightly less information)
CHANGE: Deco plan is updated much faster
NEW: Information menu shows hardware version
It contains RX firmware 1.39 for all OSTC 2 TR users.
Die neue hwOS sport Firmware 10.64 ist jetzt zum kostenlosen Download verfügbar:
Für alle Nutzer der 10.56 oder später ist dieses Update (immer noch) dringend empfohlen:
BUGFIX: Hardware versionen 13-xx-xx und 58-xx-xx konnten einfrieren für alle Versionen 10.56 oder später
[10.64]
[10.63]
BUGFIX: Der flache Bereich am TG-Ende wurde nicht zum Oberflächenintervall addiert
BUGFIX: Die Durschnittstiefe im Logbuch wurde ohne den eingestellten Salzgehalt angezeigt
CHANGE: Temperaturwerte im Logbuch werden jetzt in gelb angezeigt.
[10.60]
BUGFIX: Oberflächemodus konnte bei bestimmten Hardwareversionen einfrieren
BUGFIX: Mögliches Bluetooth Problem beim alten OSTC sport (rote Taster)
CHANGE: Standard-Sprache in der EN/DE Version ist jetzt wieder Englisch
[10.58]
BUGFIX: Versionsnummer wurde im Oberflächenbildschirm nicht angezeigt
BUGFIX: Taster konnte auf dem Lader "durchrollen"
[10.57]
FIX: Nullzeit im Großbildmodus
FIX: Bluetooth bei alten OSTC sport (Rote Taster)
[10.56]
NEW: Fünf statt drei Gase
NEW: Optionale, 2. Gewebegrafik mit Markern für GF_low, GF_high und M-Value (Details: https://heinrichsweikamp.net/downloads/ ... GF_web.pdf )
NEW: Neuer Dekoplanner und Simulator
NEW: 2. Decoplan kann jetzt auch in der hwOS sport eine Gasverbrausberechnung über alle Gase durchführen
NEW: Optional konfigurierbare "Gas Wechselzeit" und "Erweiterte Stops" (Der Gaswechsel kann auf den ersten echten Dekostopp verschoben werden)
NEW: Konfigurierbare Aufstiegsgeschwindigkeit
NEW: Unterstützung für neuere Hardwareversionen (OSTC sport und 2 TR)
NEW: 2. Layout mit großer Schrift (Und etwas weniger Informationen)
CHANGE: Dekoberechnung ist wesentlich schneller geworden
NEW: Informationsmenü zeigt Hardwareversion an (Für besseren Support)
Es enthält die RX firmware 1.39 für alle OSTC 2 TR Benutzer.
How to install: viewtopic.php?f=6&t=14509&sid=523868e80 ... 5f630b93c2
Re: hwOS Sport: New Firmware 10.64
Posted: 26 Apr 2020, 11:00
