Temperatue
Posted: 13 Jan 2010, 14:16
I've push the set temperature button in JDIVElog and now my ostc temperature is no more correct (error of about 2-3°c).
What the best procedure to set it up back?
I set it up back by comparaison with a thermometer but ...
It seems that when connected to the PC the displayed temperature slowly encrease. For example when I turn it on it indicate 22.3°c and after about 5' of connection it was already 22.8°c. Temperature near the ostc is 22.6 and didn't change. ostc and thermometer was at the same place for hours. I suspect it's because the batterie is charging. Maybe better to do it in a liquid but can't put ostc in the water when connected to the pc.
Or the best way is just to setup immediatelly after connecting to the pc before is has time to heat?
ps: of course aving ostc display 22.3 when actual temperature is 22.6 is quite good. My main question is: do you also observe this temperature increase when connected?
Ghislain
Ghislain
