OSTC+ Tech is not charging since the update
Posted: 04 May 2020, 22:00
Hi guys
I have a new problem with one of ours OSTC+ Tech. Since the update to the new firmware it won’t charge any more. The charging dongle is flashing green but faster than normally. Does anybody have a solution for this problem?
An additional minor Problem with Bluetooth Connection to my iPad. It will show the OSTC, but when you tap onto “connect” button, the button would disappear - this was the case also with the previous software version.
The second OSTC is charging normally and also the connection to the OSTC Configurator is working without problems.
