Two big problems. Firmware issue?
Posted: 13 Jul 2020, 14:25
Hi, OSTC 2 on 3.11.
Two new problems. Used for diving two weekends in a row, no issues.
Today, new issues:
1) OSTC would not turn on from deep sleep. Tried shaking, rotating for a long time. Nothing. Placed on charger and after about 5 minutes it booted.
Seemed fine, except time was 0500. Local time (correct at last use) was 1300. Strange but no big issue. I will reset via Bluetooth app. Battery level was about the same as when I put it away.
2) Connect to Bluetooth app. Update time as I have done many times. No issues. Disconnect from Bluetooth. Issues. OSTC displays:
Starting...done.
Service Mode enabled
Exited
And it now has been stuck on this screen for the past 20 minutes. I am assuming when it has run out of battery in probably a week I can recharge it and get back into the menus. None of the buttons respond. App can still detect it via Bluetooth, but cannot connect.
Is this a firmware issue? Or is my OSTC dead again?
Today, new issues:
Starting...done.
Exited
