hwOS TECH: New Firmware 3.15
Posted: 24 May 2021, 17:34
The new hwOS tech (for OSTC3, plus, cR, OSTC 2 and OSTC sport (mod. 19)) firmware 3.15 is now available for download:
This update is (still) strongly recommended for all users of the 3.03 or 3.05: OSTC with hardware versions 13-xx-xx and 58-xx-xx could hang up with single-language versions of 3.03 or 3.05
[3.15]
NEW: Support for new pressure sensor type in OSTC 2 and plus
NEW: Several changes in the different language versions
CHANGE: Tweak gas use routine to work with unplanned changes (Switching to inactive gases)
NEW: Big dive mode menu in big layout view
BUGFIX: fix pulsing brightness in ECO on some hardware versions
CHANGE: support for internal hardware changes
CHANGE: adjust gas density parameters to match upcoming new ISO standard
[3.13]
NEW: Support for current hardware version of OSTC 2 and plus
FIX: Abort on unknown parameter in comm mode
CHANGE: Several small language fixes
CHANGE: increase battery safety margins for Saft (T0) and 16650 batteries (T4)
[3.12]
BUGFIX: Deco paramters (Saturation/Desaturation) were shown false in the logbook and surface screen (Non-GF deco mode only)
BUGFIX/CHANGE: Saturation/Desaturation parameters are moved into thier own Sub-menu (Non-GF deco mode only)
BUGFIX: Screen startup behaviour (OLED Limited Edition only)
[3.11]
BUGFIX: configuring deco gases via the mobile Apps was not possible
CHANGE: French language fixes
[3.10]
- Hardened all USB/Bluetooth communication against data losses and timeouts
- A new Firmware Recovery Feature has been added: the currently active firmware can be backed-up and restored later on while other firmwares have been loaded thereafter. The feature is accessible via Settings -> System Settings -> Reset Menu -> Reboot and becomes available with the first firmware load after the V3.09 beta 4 (or later) is already on the unit.
- New option to acknowledge the most recent warning in dive mode (Left press -> Ackn?)
- Removed option 'ascent speed', ascent calculation is done with a fixed speed of 10 meters/minute now (equals the ascent speed limit by Bühlmann).
- Improved calculation accuracy of the initial ascent. Remark: this will have a slight impact on the resulting deco schedule compared to firmware 3.08.
- The deco calculator now figures in the salinity setting.
- Aligned logbook and last dive summery of avg and max depth regarding rounding and incorporation of salinity setting.
- Done some fine-tuning of depth outputs when using imperial units (feet).
- In dive mode, sometimes the temperature was not shown any more after a gas change - fixed now.
- The menu system around setting up the dive mode & settings has been decluttered. All settings are now sorted into the groups dive setup, deco setup, SAC (gas needs) setup, ppO2 setup and stops & depths setup.
- There is a new option "Swap on empty" in Dive Setup -> SAC Setup. It is only effective if "CalcGas(B/O)" is switched on, too. If both options are switched on, the deco calculation will switch to another tank (i.e. gas) once the tank of the current gas is calculated to be used up. This function can be used to automatically calculate a contingency in case of running out of a deco gas, as the deco calculation will then continue to calculate a deco making use of the spares from the another gases carried. Another application is with two or more tanks holding the same gas (i.e. independent double configuration, side-mount), as the calculations will then take the cumulative amount of gas carried into account before raising a gas needs attention or alarm.
- Fixed the urge of the better gas hint to always favor one specific gas out of a set of two or more gases that have the same change depth.
- For dives done on firmware >= 3.08 the logbook will have one more pageshowing the tissue pressures and supersaturation levels as of at the
end of dive (i.e. when surfacing).
- As long as a gas or diluent is currently selected as breathed, it can not be set into the lost state any more.
- When changing the battery or doing a cold start, the current CNS value does not get lost any more.
- During loading of a new firmware the clock will not loose time any more (on old firmware it became late by about 15 sec on each firmware update).
- When run from a 3.6 V battery (either replaceable or built-in), the surface mode timeout is now extended to 4 minutes before going to sleep
mode. If the OSTC is run from 1.5 V disposables, the timeout remains at the previous 90 seconds to save on battery runtime.
- Internal improvement: the code for the internal storage system and for the communication system (firmware uploading, dive data downloading)
has been re-factored to secure maintainability for the next years to come.
- Internal improvement: the scheduler for the dive mode calculation plans (fTTS, bailout) has been completely rewritten for better maintainability.
The version has many new features and changes, but the basic settings have not changed much since 3.01 and OSTC experienced users will be fine with it at once. By popular request some settings have been extended and added. Thus the gas change is suggested again independently of an actual deco stop at the change depth and also the maximum ppO2 can be set beyond 1.6bar. As always, this applies here: Changes to the basic settings via accepted limits (GF>100, ppO2>1.6) are the responsibility of the user. In order to correctly forecast the TTS even when using more than one or two decogases (OC), a little more care must now be taken in the gas setup for such dives. For example, the MOD/change depth must also be set for the start gas (First) so that the OSTC can propose and predict all gases in the correct order. However, this still applies unchanged: Each gas from the gas list can be selected at any time in the dive. Unsuitable gases are already marked red in the gas list and a warning/recommendation is issued when selecting. The control remains however to 100% with the user.
Die neue hwOS tech Firmware 3.15 (für OSTC3, plus, cR, OSTC 2 und OSTC sport (mod. 19)) ist jetzt zum kostenlosen Download verfügbar:
Für alle Nutzer der 3.03 und 3.05 ist dieses Update (immer noch) dringend empfohlen: OSTC mit hardware versionen 13-xx-xx und 58-xx-xx konnten im Oberflächenmodus einfrieren (Nur bei den Ein-Sprachen Versionen der 3.03 und 3.05
[3.15]
NEU: Unterstützung für neuen Drucksensor in OSTC 2 und plus
NEU: Sprachupdates
ÄNDERUNG: Verhalten beim Wechsel auf inaktive Gase
BUGFIX: Hintergrundbeleuchtung konnte unter bestimmten Bedingungen pulsieren
NEU: In der Großansicht wird das Tauchmodus-Menü in großer Schrift (Eine Zeile) dargestellt
[3.13]
NEU: Unterstützung für aktuelle Platinen-Version im OSTC2 und plus
BUGFIX: Abbruch bei unbekannten parametern während der Bluetooth-Konfiguration via App
ÄNDERUNG: Eine Begriffe im Menü wurden präzisiert
ÄNDERUNG: Für die LS14500 SAFT (T0) (Nur im OSTC sport) und für die 16650 (T4) im OSTC 2 wurde die Sicherheitsmarge bei der Kapazitätsberechnung erhöht
[3.12]
BUGFIX: Die Angaben für die Sättigungs/Entsättigungs-Mulitiplikatoren im Logbuch waren fehlerhaft (Nur im Nicht-GF deko modus)
BUGFIX/CHANGE: Die Sättigungs/Entsättigungs-Mulitiplikatoren haben nun ein eigenes Untermenü
BUGFIX: Startverhalten des Bildschirms (Nur OLED Limited Edition)
[3.11]
ÄNDERUNG: Updates bei der Französischen Sprachversion
[3.10]
BUGFIX: Verbesserte Berechnungsgenauigkeit des Erstaufstiegs. Bemerkung: dies wird einen leichten Einfluss auf den resultierenden Dekoplan haben, verglichen mit der 3.08
ÄNDERUNG: Das Menüsystem zum Einrichten des Tauchmodus und der Einstellungen wurde aufgeräumt. Alle Einstellungen sind jetzt in die Gruppen TG-Einstellungen, Dekompression, SAC (Gasbedarf)-Einstellung, O2 Partialdruck und Stopps und Tiefen einsortiert.
NEU: Für TG mit Firmware >= 3.08 wird im Logbuch noch eine weitere Detailseite mit Sättigunsdaten angezeigt
NEU: Eine neue Firmware-Wiederherstellungsfunktion wurde hinzugefügt: die derzeit aktive Firmware kann gesichert und später wiederhergestellt werden, während andere Firmwares geladen wurden. Die Funktion ist zugänglich über Konfiguration -> System -> Reset Menü -> Neustart/Backup und wird mit dem ersten Laden einer Firmware verfügbar nach der 3.10 (oder später).
ÄNDERUNG: Bei Betrieb mit einer 3,6-V-Batterie (entweder austauschbar oder eingebaut) wird der Timeout auf 4 Minuten vor dem Einschlafen verlängert. Bei 1,5V Batterien bleibt es bei 90 um die Batterie zu schonen
ÄNDERUNG: Interne Verbesserung: der Code für das interne Speichersystem und für das Kommunikationssystem (Hochladen der Firmware, herunterladen der Tauchdaten) wurde umstrukturiert, um die Wartbarkeit für die nächsten Jahre zu sichern.
ÄNDERUNG:Interne Verbesserung: der Scheduler für die Tauchmodus-Berechnungspläne (fTTS, bailout) wurde zur besseren Wartbarkeit komplett neu geschrieben.
[3.08]
Die Version hat zahlreiche neue Funktionen und Änderungen, in den Grundeinstellungen hat sich jedoch nichts Grundlegendes zur 3.01 geändert und mit dem OSTC erfahrene Benutzer werden gleich damit zurecht kommen. Auf vielfachen Wunsch hin wurden einige Einstellmöglichkeiten erweitert und hinzugefügt. So wird der Gaswechsel wieder unabhängig von einem tatsächlichen Dekostopp auf der Wechseltiefe vorgeschlagen und auch der maximale ppO2 lässt sich über 1,6bar hinaus einstellen. Wie immer gilt hier: Veränderungen an den Grundeinstellungen über anerkannte Limits (GF>100, ppO2>1,6) liegen in der Verantwortung des Benutzers. Um die TTS auch bei Verwendung von mehr als einem oder zwei Dekogasen (OC) korrekt zu prognostizieren muss bei derartigen TG jetzt etwas mehr Sorgfalt im Gas Setup angewendet werden. So muss z.B. auch für das Start-Gas (First) die MOD/Wechseltiefe eingestellt werden damit der OSTC alle Gase in der richtigen Reihenfolge vorschlagen und vorausberechnen kann. Hier gilt aber weiterhin unverändert: Jedes Gas aus der Gasliste kann beim TG zu jedem Zeitpunkt gewählt werden. Unpassende Gase sind dabei schon in der Gasliste rot markiert und bei auswählen wird eine Warnung/Empfehlung ausgegeben. Die Kontrolle bleibt aber zu 100% beim Benutzer.
How to install: https://forum.heinrichsweikamp.com/view ... =6&t=14509
Re: hwOS TECH: New Firmware 3.15
Posted: 25 May 2021, 21:45
by dadefay
After downloading release 3.15, I decided to download the dive I did this morning with 3.14 beta 2 (yesterday dives already downloaded before) : instead of the last dive, the almost the full logbook was downloaded (about 200), until the transfer crashes. Not a big problem, if it occurs only once.
Regards.
Posted: 26 May 2021, 09:26
by Clownfish
I also used today and same thing happened, downloaded over 140 dives.
Posted: 26 May 2021, 16:08
Box "Force download of all dives" ticked?
Posted: 26 May 2021, 21:23
by dadefay
Hi guys,
No, I did not check the "Force download of all dives" box. Anyway, today only the new dives were downloaded (two CCR dives, nothing to signal about 3.15).
Posted: 27 May 2021, 07:06
by gr3yw0lf
hm ...
in subsurface you can always check/uncheck the dives to download. so, if you don't take a look at what you'r doing something like that can happen. I don't think it is an OSTC issue - my peregrine shows the same behavior in subsurface-mobile. but I will test my OSTC this weekend.....
Posted: 27 May 2021, 08:55
dadefay wrote: 26 May 2021, 21:23 No, I did not check the "Force download of all dives" box. Anyway, today only the new dives were downloaded (two CCR dives, nothing to signal about 3.15).
Thanks - I'm pretty sure this should be fine now. We made no changes whatsoever here.
Posted: 27 May 2021, 10:13
by Clownfish
Box to download all was not ticked. It takes a long time to just get the list, then you can unselect all and select the one/s you want.
This has happened before after an upgrade.
Posted: 30 May 2021, 09:35
by gr3yw0lf
hi all
tested it right now....
connecting my OSTC+ to subsurface without checking the box "force download all dives" all dives of my OSTC are marked to download or as "new" dives (tested it in subsurface desktop AND mobile - both the same). easy solution - just klick on "deselect all" an mark just the dives you want to download -> done. quick and dirty.
I gonna post this issue in the subsurface-group, 'cause I think its not a HW-issue...
Posted: 10 Jun 2021, 04:37
by gr3yw0lf
hi all
still waiting for a response in the subsurface-forum (dirk seems to have some "bigger" issues than that) but I did some dives in the meantime - and this behavior didn't show up again.
it seems to me, that subsurface recognises the new firmware and so all dives are "new" ones, but this happens (on my devices) just the first time after the firmware-upgrade. nothing to worry about.....
Posted: 26 Jun 2021, 14:02
by dadefay
I did a dozen of CCR dives with this release, no new problem to signal.
But these days I'm in a very sunny place, and I say once more that the dark blue text is totally unreadable in these conditions. Despite what a guy wrote some months ago on this forum, i.e. gas configuration is not supposed to be done on the boat, one can meet problems leading to a gas change just before jumping in the water : that's what happened to me yesterday, and I was unable to change O2/He settings alone ! I had to request help from a very young diver with young eyes...
Please consider changing this colour for a clearer one.
Best regards.
Posted: 28 Jun 2021, 00:10
by ClaudeDive
Also Trimix Instructor and diver in the Var where the sun shines as everyone knows,
The blue color of the deactivated throttle is for me perfect and easily identifiable even in direct sunlight even with my eyes not so young as that ...
Obviously you should not look at the OSTC with sunglasses and even less with polarized lenses!
A lighter color was previously, and was not suitable for questions of differentiation with white, and even less for color blind people of which I am a part,
So thank you for keeping the current blue in service for more than 3 years and which has been the subject of very little notice!
Thank you OSTC for this current color identification which is perfect.
Cheer
Posted: 28 Jun 2021, 00:42
by dadefay
Hi again,
I don't talk about deactivated gases in the gas list, but about the first line of the [b]Gas configuration[/b] page : this line indicates the gas composition, so it is more than important to see what you do ! I don't understand the need to have a different color for deactivated gases [b]in this context[/b]. Of course it is possible to activate the gas - the line turns white - then to change the composition and finally to deactivate the gas, but this is a little tricky...
Regards.
Posted: 28 Jun 2021, 10:44
Finding a color scheme that can be read by all (or most) users easily is not easy.
We have a small optimization planned and that is using two different (user-configurable) brightness settings: One for dive mode and one for surface mode. While the ECO setting is sufficient even in bright conditions under water it's difficult to see on the surface under some conditions.
Posted: 11 Aug 2021, 18:50
by artome
Hello.
My unit is the number #21486.
I try all your solutions, but I can't go from the 3.13 to the 3.15
Sport helper don't work anymore.
My unit always reboot on the 3.13.
What can I do after all?
Thanks.
Finally sport helper works well, the bluetooth logo must be on the ostc sport, and the little program debug it...
It was difficult but when you apply the good method, it's easy...
Posted: 15 Oct 2021, 11:49
