Falsche Batterie-Anzeige bei 2 Sport / 10.70 // Incorrect batt. values
Posted: 19 Jul 2021, 08:39
Hi all,
I changed the 1.5 V battery in my wifes new 2 Sport and updated to 10.70.
Now I use a Saft LS14500.
After changing the battery I was not aked about the batterie - type like I know it from my own 3.
The display says that the capacity is 82% - but the battery is brand new.
I switched the batteries brtween my 3 and my wifes 2.
The 3 says 100%, the 2 stays with 82%.
I went back to a normal AA 1.5V and the 2 gives 1.5V and 100%, then back to the new LS14500,
and it again says 3.5V 82%.
Also the 2 tends to give a lower temp (approx 2 - 3 degrees) an a littel bit higher pressure (~100 hPa) and
those values tend to change every few seconds up and down. My 3 is very constant with those values.
Is this normal?
How can I set the correct battery-type in my wifes 2 Sport?
TIA
flo
Is this normal?
TIA
flo
