Charging problems
Posted: 05 Oct 2021, 07:55
I have the following problem trying to recharge the battery on my OSTC plus.
The battery was at 15% when I put it to recharge with the qi charging pad, but the screen stayed black and the qi charging pad kept a constant red light.
I have changed the battery for a rechargeable one. I have selected new battery in the menu and the option T2
When the ostc was reset the battery level was at 0%. I know this is normal and a full charge is required to calibrate the battery capacity.
I have placed the qi charger pad and the result is that it remains a solid green light and after a while the OSTC goes into dive mode, showing a depth of 2.9 m and the divetime marker working. The battery level stays at 0% the entire time.
In order to get out of this mode I have to remove the battery from the OSTC.
I need to solve the problem since tomorrow I start a 5-day technical diving trip.
Thanks in advance
Thanks in advance
